WARNING: n00b Question ALERT! FSTB, RSB?
Hi all,
What is an FSTB and an RSB and what do they do? I read about them a lot. I'm thinking it's a Front (Something) Traction Bar and a Rear Stabilizer Bar. I may be right, and I'm sure they do something about traction and stabilization respectively, but could someone explain it a bit to me? Please bear in mind that if you have a computer or networking problem I can probably help you out, but as far as when my car needs repairs, i pull up to Jeff the mechanic's shop and say "Jeff, I broke my car again."![slant](https://maxima.org/forums/images/smilies/slant.gif)
Dan
Dan
Okay, Noob...only 'cause I'm feeling good
about the New Year I'm not gonna give you a bunch of crap but next time...use the 'Search' function, okay?
FSTB= Front Shock Tower Brace, basically a metal connector between the two front shock towers that stiffens up the front end/reduces flexing in the whole front unit body assembly. Specially effective if the car is lowered and/or if you live in a rough road environment, 'cause either of those two conditions create the large suspension deflections or large suspension loadings that create chassis flex.
RSB = Rear Sway Bar (or also Rear Stabilizer bar) designed to increase the roll stiffness of the rear suspension and balance the stong inherent understeer designed into our cars.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Re: WARNING: n00b Question ALERT! FSTB, RSB?
Originally posted by dcook22
Hi all,
Dan
Hi all,
Dan
Cheers
AA
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
I'm sure some others will tell you to do a search on the forum for those two things, but here goes...
1) FSTB - Front Strut Tower Bar. It gets installed between your two front strut towers in the engine compartment. It helps keep everything more ridged during hard cornering, improving steering repsonse. An FSTB can be had for under $50. It makes for a good 1st or 2nd inexpensive mod.
2) RSB - Rear anti-Sway Bar. It gets installed along the rear beam underneath your car. It helps the car reduce roll, and makes a dramatic change in the feel of your suspension if you are going to keep all else stock. Depending on the brand you get, it will run you from about $130 on up. A must-have mod, especially if you don't plan on changing anything else with your suspension.
Hope this helps. Peace.
Re: Re: WARNING: n00b Question ALERT! FSTB, RSB?
Hi all,
thanks for the info. I actually did a search for FSTB and got back 4247 result threads, the first 10 - 20 of which were about installations or prices, but no real info about what these things were. I guess that knowledge was assumed by the posters. I felt the question was simple enough for basic and quick responses, and would cause little harm or angst.![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
I figured it would be best to warn the populace of a n00b question, rather than just post the question without trying to find the info. I will certainly search with a greater dilligence in the future.
Now that I have the basic info, I can read the past threads with greater understanding and post future questions about the pricing, installation and usefulness of these items with preponderant exactitude and utility.
I thank you for your illumination, caveat and above all your indulgence.
With Gratitude,
Dan![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
p.s. I got a thesaurus for Christmas.
With Gratitude,
Dan
Re: Re: Re: WARNING: n00b Question ALERT! FSTB, RSB?
With Gratitude,
With Gratitude,
Dan
"Caveat" though? Think you may be a little off on that one (my caveat - I don't have a thesaurus handy )
Re: Re: Re: Re: WARNING: n00b Question ALERT! FSTB, RSB?
This is from Dictionary.com
8 entries found for caveat.
Entry: caveat
Function: noun
Definition: warning
Synonyms: admonition, alarm, caution, caution, commonition, forewarning, information, monition, sign
Concept: warning
The others warned me that I should search for my answers before posting or I would be taken to task. That was their caveat to me.
Caveat Emptor. Let the buyer beware. (Be warned)
Dan
Newbie...check the FAQ thread before asking these types of questions. It will help keep down the flaming. Also for those that replied earlier busting his *****...why did you tell him what they were and bust his *****? Plus, there were about 4 or 5 of the same explanation on what they were. Man....wasted space.
RSB should be one of your first mods. It dramatically helps the suspension out and it's very easy to put on. I like you could do anything with computer networking, etc., but when it came to the car, if it wasn't an oil change or spark plugs, I was dumbfounded. You'll find most of this stuff is easy.
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
