2K2 Auto SE ATF Capacity?
Old Jan 6, 2003 | 11:38 AM
Shaydz's Avatar
With a flush, has anyone replaced their 2002 SE Auto ATF?
Capacities are not shown in the manual and I've read 14.5 somewhere and heard 10 quarts.
I've searched and saw nothing definitive. Would like to hear from someone who's done it. Probably going with Amsoil synthetic from Mark.
Lastly, how do you like it? I've got 14,500 miles nad wasnt to do this as early as possible.
I've changed out the oil with Mobil-1 synthetic and have been surprised at how smooth the engine feels and sounds.
Old Jan 6, 2003 | 01:04 PM
[maxi-overdose]'s Avatar
I would put in about 10 and then do adjustment. Just warm up your tranny in the garage will be ok.
flush with a machine - u will need a bit more ATF.
flush by taking off the pan and draining the remaining ATF from the hose to radiator will need a bit less.
FYI : I strongly suggest you to put less ATF in there and measure it again about 2 weeks later. Because new oil will be broken-in and it will expand a little. I needed to drain about 3/4 quart out of the tranny after 1 month.
Old Jan 6, 2003 | 01:20 PM
dlee27's Avatar
I don't think ATF expands after break-in. It expands with temparature. You need to check the level after warm-up when idling. In my experience cold level is not accurate. This proceduce is explained in manual so please check it first.
Old Jan 6, 2003 | 01:31 PM
Shaydz's Avatar
Thanks....
I will do the 10 qts and keep an eye on it.
Thanks all. Any impressions on using a sythetic in the 2K2 are appreciated as well.
Old Jan 6, 2003 | 02:30 PM
Lumbee799's Avatar
Re: Thanks....
Shaydz, have you tried calling Southern States? The service department might know (then again they might not).
What are some prices for Redline and Amsoil per quart?
Old Jan 6, 2003 | 03:18 PM
I always checked at 150F and it expands after 2 weeks of running with new ATF.
Shadyz : Synthetic ATF or engine oil? both benefit the engine/tranny if u've properly broken in your engine/tranny.
Old Jan 6, 2003 | 03:34 PM
Shaydz's Avatar
Re: Re: Thanks....
Check your email...
Old Jan 6, 2003 | 05:13 PM
PCGuRu2K's Avatar
When I just drained the atf on my auto 2k1 I just refilled with about 4 qts.. I didn't drop the pan which hold about another qt...
Old Jan 6, 2003 | 06:15 PM
Virus's Avatar
I think I used 11 or 12 courts. The place where I got it done said that they were unable to add more once the machine starts so it's better to use more than less when having the auto tranny flushed. I used Amsoil ATF.
TallTom
57
Oct 14, 2025 05:16 PM
AaronL
Aug 8, 2020 10:31 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
