Question on changing brake pads
Old Jan 10, 2003 | 06:49 AM
  #41
MaximaMan77's Avatar
Originally posted by asu174
44,000.
The rotors were turned and the pads replaced about 20,000 miles ago. I also drive them fairly hard, but not like a lunatic.
With 44k on the car and 24k on cut rotors with the way you say you drive the front pads most likely are getting thin. It's not a good idea to cut rotors a 2nd time as they will be prone to warping. If you don't want to spend any real money ($300 min.) then I would get some average pads, spend no more than $50 for the front, and just replace them with out cutting the rotors. No matter what anyone says it's never a bad idea to bleed the calipers when doing a pad change. It takes no more than 5min. per side uses very little fluid and gives you peace of mind. This is a quick fix and solves your problem now. Like I said before you should have a friend help you the 1st time.
When you buy the pads most autoparts stores will have a hardware kit for the car too but you have to ask. The kit has new wear plates any springs and retainer clips you will need if the store doesn't have it the dealer will, it's not expensive. You will also need some grease for the caliper bolts, relube them when reassembling. And last but not least repacking the bearings with bearing grease. Oh and a can of brake cleaner to spray the rotors down when your done so there is no grease or oil on them.
This is how to do it the right way anything else is cutting corners...
Now if you want better preformance and have the extra cash then you may want to think about some new rotors for the front with better pads and some Goodridge stainless braided lines (all 4). If not plan on this for the future. The uncut rotors will eat the pads up quicker so you will not get 20k out of'em. The uncut rotors will also get very hot when seating the new pads so don't dog the car out right away and after any hard braking keep driving the car to cool them down.
At 44k you may need to look at your rears also.
I hope this helps. Good luck,
Adam
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
