Auto Trans Question
Old Jan 4, 2001 | 09:53 AM
kpark's Avatar
I've have my Maxima since September and had my TCM replaced about two months ago since I was experiencing the "shift delay" from 1st to 2nd gear. I still have the "shift delay" but the shift is just rougher when I'm not reving high and sometimes the trans seems to hunt between gears. I've brake-tourqed a few times and I heard that it is very bad for your trans. Do you think I need a new transmission? I have been experiencing irregular shifting.
Old Jan 4, 2001 | 10:13 AM
RussMaxManiac
That is normal. The ECU learns how you drive and if you change from the way you normally drive to aggressive it will get confused. Sorry but its not instant, and many tranyns do get confused. Not just Nissans.
Old Jan 4, 2001 | 10:50 AM
Paul6speed's Avatar
Let me add to what Russ said...
If you are driving at a speed at which its close to a shift point, your tranny will try the higher gear first and it might decide to go lower if needed. There might be a slight delay in shifting due to this process. For certain gears and speeds, I can predict how the car will shift.
Old Jan 4, 2001 | 10:52 AM
kpark's Avatar
Thanks for your reply Russ2kSE, I hope that is the case.
Old Jan 4, 2001 | 11:02 AM
wht2kmax
Hey kpark
Where did you get the "25th" AE door sills.
Looked everywhere, was only able to get the 20th AE door sills.
Dayam, you are good!!!
J/K
bumpypickle
Sep 20, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
Maxboy23
Sep 4, 2015 06:04 PM
