y-pipe with stock muffler...........
Old Jan 9, 2003 | 04:57 PM
2kseman's Avatar
is stock muffler efficient enough to evacuate the extra exhaust gas from ypipe? simply put, is stock muffler a bottle neck in regards to ypipe? thinking about getting a better muffler, please chime in........
Old Jan 10, 2003 | 02:07 PM
Loe max's Avatar
The factory unit is pretty high flow itself. Your only losing about 1-2HP vs. a free-flowing aftermarket exhaust. If the louder rumble is important to you and you can live with it, go ahead and get one.
Old Jan 10, 2003 | 02:14 PM
LatinMax's Avatar
I agree with ScreamingVQ. I have the entire exhaust system upgraded except the muffler and only lost 1.2 hp (Cattman setup) I went that way because I did not want the loud muffler sound. I tried it but did not like it and sold the muffler part.
Old Jan 10, 2003 | 03:40 PM
Loe max's Avatar
Besides, the factory muffler already gives off a nice quiet raspy rumble with the Intake/Y-pipe combo at low rpms, smooths out in the middle range and flat out rips at higher rpms. The B-pipe just amplifies it alittle more
Old Jan 10, 2003 | 04:30 PM
asu174's Avatar
Clay Aiken has fancy genitals
I have this setup as well and I am very pleased with it. I had an aftermarket muffler before and it was wayyyy too loud. The stock muffler is plenty sufficient and I did not feel a bit of difference when I went back to using it.
Old Jan 11, 2003 | 12:12 PM
2kseman's Avatar
thanks for the inputs, i'm not into that "loud" thing myself....if only losing 1-2hp with high flow muffler, i'll stick with the stock, save some $$ and besides, i like seeing ppls expression as i leave really quick in stock looking max
Old Jan 11, 2003 | 03:22 PM
Loe max's Avatar
If you want it slightly louder, you could just have the factory resonator removed and keep the stock muffler or run a straight pipe instead of a cat
Old Feb 3, 2003 | 09:55 PM
02MaximaSE's Avatar
Thats what im planning on doing.
Old Feb 3, 2003 | 10:09 PM
cmb7's Avatar
Re: y-pipe with stock muffler...........
I was inquiring about this the other day. You might benefit from the info as well. The link to my thread is below. Good luck. I've all but ordered both the cattman Y-pipe and b-pipe, and keeping an OEM muffler. -Chris
http://forums.maxima.org/showthread....hreadid=186135
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Quickywd01
Sep 21, 2016 09:36 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
