So anyway my wheel fell off
Yup, my bad luck, I heard this noise, and stoped twiece to see what it was, checked the tire, coilover, s/c, everything i could think would make noise.
Got back on the highway, cuz it went away on the off roads, and came back, keept getting worse and I'm praying to god to give me a break, pull over again, and 5 feet inside an amaco, BOOOOOOOOOOOOOM thought the tire was gone...Nope wheel stud broke, striped other 4 lugs and fell in bending the fender the inner fender, bending and cutting up the inside of the wheel and landing on the 13" brake rotor.
Re: So anyway my wheel fell off
Re: Re: So anyway my wheel fell off
Originally posted by Y2KSESteve
Holy crap! Good thing you werent at highway speeds when that happened and good to see you're alive!!
Originally posted by K Pazzo 6
what could of caused your wheel to fall off like that
But one could have striped, the brake kit causing heat, who knows...ONe stud broke and the rest failed. ****ing nissan. What more can I say.
I was checking out my bro's SHO last weekend. he has locks on his new wheels. I noticed a few lugs loose, not even hand tight. He was like damn, I just tightened those.
When he got his key out, he also had an original lug there. So, we decided to compare. It became obvious why his locking lugs were backing off on their own. There was too much play in the threads. Even when the lug was all the way on (but not tight), it would wobble when pushed. However, the OEM lug would not. Its clear that that OEM lug was making ALOT more thread contact.
Given everything I've seen with locking lugs backing off, it might not be a good idea to use all 5. Or make sure that the brand you choose fits on the threads properly. I'm pretty sure my bro had Gorillas :/ All of them were like this.
well...same thing happened to my friend...at a bowling alley...we left home and a mile later... clunk....clunk...every rotation...
they were getting jacked...but there was one lug they couldnt get off..the clunking got worse...we drove ome at like 5 mph and found the lugs to be loose. The lugs had 5 indentations in them..as in..the thiefs used a sort of gripping device...
Re: Re: Re: So anyway my wheel fell off
Thats the question, I'm thinking sombody got the one wheel lock and that put stress on the other 4, but it's just a basic theory.
BUT why are you hating nissan? You think someone did something to it and that's nissan's fault? If it really is that "one stud broke and the rest failed" then I can maybe see blaming nissan but if someone was messing around, you don't know what they did to cause this failure... especially if they got a few loose or put a lot of stress on them trying to get them off and then you went 110 on a part that's been compromised.
Re: Re: Re: Re: So anyway my wheel fell off
Originally posted by 2k2wannabe
Good you didn't get hurt. You can fix a car.
Sounds like you didn't use a torque wrench to put them on. Also note that when you put new wheels on the lugs will loosen over 20 or so miles then you should re torque them. Not sure if this is the cause or scenario for what happened just trying to help. Anyway im glad no one was hurt.
if you had used a torque wrench, they probably would have been more loose. 85 ft/lbs doesnt feel tight to me at all.. But anything more will warp your rotors :/ I've never had a loose lug at 85 tho.
Btw, my bro had McGuards, not Gorilla.
I think the moral to the story here is being very careful using 5 locking lugs.. and if you do use locking lugs (or any non-OEM lug), be sure the thread is right, the seat is correct and doesnt wobble on the stud. I guess those one size fits all lugs have alittle extra tolerance in the thread gap.
Of course, it could have been a theft attempt, but I cant count the number of loose locking lugs I've seen when more than one lock per wheel is used.
Thanks guys. I'll never really know just what caused it but I do know a few things. The nuts where not lose, cuz they striped off the bolts. 4 of the lugs where still in the wheel, one was missing, and the spacer behind it was right by the wheel when i picked it up/ got it out from under. So with that, it's hard for me to think they where lose, when all the remaining studs where striped, and one of the 4 remaining lug nuts had the broken bolt in it.
06-06-2017 02:01 PM
Andy29
09-29-2015 05:32 AM
