Shifter Knob Replacement
Old Jan 4, 2001 | 02:12 PM
Sherwood
I've purchased a new Shift **** for my 2001 Maxima SE 5spd and would like to be prepared. Does anyone know if the shifter has any torque screws I'll run into or does the stock **** just twist off.
Old Jan 4, 2001 | 06:32 PM
Maximizd's Avatar
Twist really hard, counterclockwise, use a wrench over a towel and just break the seal.
Old Jan 5, 2001 | 05:14 AM
Jeff K's Avatar
I used a strap wrench on the shift **** to break it free. You will have to concentrate all your force on the top of the ****, the threads are up higher in the stock shift ****.
I tried a shorter shift **** for a week but the center console is higher in the 5th generation and interfers with
quick shifts. I am back to stock.
Old Jan 5, 2001 | 09:16 AM
irvine78's Avatar
YEAH~ RIGHT~!
with all due respect....cut the damn thing off your shaft...
i tried everything....the towel, the wrench....hmmm...i should have tried the monkey wrench....
and then i ended up using a saw to saw it off!
hehe....
i mean, who cares about the stock shift **** anyway?
-peace
Old Jan 5, 2001 | 06:15 PM
blackmax2000's Avatar
Put it in first or reverse and put a strap wrench around it and hit it hard in a counter clockwise direction. Should break the glue after a few hits.
Old Jan 5, 2001 | 08:48 PM
Maximizd's Avatar
Re: YEAH~ RIGHT~!
hehe....
-peace
Damn man, you SAWED it off??? That's a bit EXTREME for me. My replacement **** used the stock threads anyway, so I wasn't about to SAW anything off MY shaft! It really didn't require THAT much force to just twist it off.
I suppose you chisel your lug nuts off when you rotate your tires, eh? Jaws-of-life when you lock the key in the ignition?
Old Jan 5, 2001 | 08:59 PM
y2kse's Avatar
Re: Re: YEAH~ RIGHT~!
Damn! And here I was just going to recommend removing the stock shift **** with a little C4!
Old Jan 5, 2001 | 09:30 PM
ohboiya's Avatar
can I just ...
I'm going 2 get the SMC STS ... so can I just leave the stock **** on the stock shifter & pull out the stock shifter with **** attached?
Old Jan 6, 2001 | 02:28 PM
y2kse's Avatar
Re: can I just ...
Did you check out the Courtesy STS, ohboiya? It's almost $100 cheaper than the SMC and there's a full write-up on the install. Check out the link in my sig.
Old Jan 6, 2001 | 05:20 PM
ohboiya's Avatar
Re: Re: can I just ...
Hey .. tkx 4 the heads up ... I checked out the notes by VBX ... very detailed! That's amazing!
N e ways ... after reviewing his notes ... I'm more inclined 2 get the SMC ... I can get it 4 $150 shipped so I'm pretty pleased ...
Ciao
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
vingodine
45
May 21, 2016 12:46 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
cruce91
Sep 20, 2015 10:23 AM
