Need help buying a torque wrench
I recently installed my FSTB and I borrowed my friends torque wrench for the job. It was a 1/2 drive which really gave me a lot of leverage when removing / installing the bolts. I figure it was about time that I added one to my collection, but I'm confused as to which to buy? I'm leaning toward getting a 3/8 inch drive one because most of my sockets are that size.
I am going to get a Craftsman one (but open to other ideas) and they have torque wrenches that have varing scales:
3/8 in. sq. drive beam-type; 0-75 ft./lb (1 lb increments) = $29.99
3/8 in. Drive; manual turn type; 25-250 ft./lb (1 lb increments)= $69.99
3/8 in. Drive; digital read out type; 5 to 80 ft. lbs (.5 lb increments) = $89.99
The advantage (other than price) of the beam type (with the needle on a scale) is that they can be calibrated. The other 2 I beleive "click" when you hit the selected torque, but cannot be easily calibrated.
Another concern is what range I should get? For just normal maintanence stuff (tires, oil changes, light modding (RSB), etc). I know that I needed 34 lbs (FSTB) but how much higher or lower do I have to go?
Also, other than the tires and RSB how much use will I get out of this thing? Am I better off going with the cheap one?![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
Thanks.
Thanks.
Re: Need help buying a torque wrench
Thanks.
Thanks.
You will read peeps that say it to costly, not costly enough and so on. That is a personal decision. But when it comes to tools, I have witnessed more than once "you get what you pay for". The $$$ value though is up to you.
As for calibration, I am not sure how/what to address on that. Yes, the non-beam type "click". I have used beam type and dont prefer it. My .02.
BTW, the digital is merely a number on a label wrapped around the inner sleeve in a window versus a stamped value on the outer sleeve of the adjuster. Its not really "digital". No LCD display.
Originally posted by ducky
Isn't the $69.95 25-250 wrench in in-lbs from craftsman? My mother-in-law bought me that one for Christmas thinking it was ft-lbs.
69.99 The stock number Sears Item #00944594000 Mfr. Model #44594 3/8 in. square drive wrench measures 10 to 75 ft lb. in 0.5 ft. lb. increments Micrometer-type scales stamped into housing show torque settings in both English and metric units
89.99 The stock number Sears Item #00944596000 Mfr. Model #44596 3/8 in. square drive wrench with digital readout. Our easiest to set and most accurate. Measures 5 to 80 ft lb. in 0.5 ft. lb. increments
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
Originally posted by Colonel
69.99 The stock number Sears Item #00944593000 Mfr. Model #44593 3/8 in. square drive wrench measures 25 to 250 in. lb. in 1 in. lb. increments Micrometer-type scales stamped into housing show torque settings in both English and metric units.
69.99 The stock number Sears Item #00944594000 Mfr. Model #44594 3/8 in. square drive wrench measures 10 to 75 ft. lb. in 0.5 ft. lb. increments Micrometer-type scales stamped into housing show torque settings in both English and metric units
89.99 The stock number Sears Item #00944596000 Mfr. Model #44596 3/8 in. square drive wrench with digital readout. Our easiest to set and most accurate. Measures 5 to 80 ft. lb. in 0.5 ft. lb. increments
Re: Re: Need help buying a torque wrench
I have the digital one myself. I went through the research and decided based upon the FSM (I read a LOT of pages) that unless you are pulling apart your suspension pieces (arms and linkages) up to 85 ft/lb tq is good enough. I got the digital one because it goes very low also. I use it on my motorcyle which require tq'in below 25 ft/lbs.
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
Oh wow, I guess I was fooled to. Good lookin' out. Yes, I just checked and it is in/lbs. My wheels probably would have fallen off if I got that one!
When you put it that way it seems like the "digital" one is overpriced. What didn't you like about the beam type? I can imagine there would be times where it would be hard to see the scale as opposed to listening for the "clicks" but I really wonder what I'll use this on and how often?
Also keep in mind % of error. Looking will give a undetermined % of error. It just was not my preference to use a beam overall. To each their own.
Keep in mind that pulley bolts are spec'd to 240 ft/lbs....so if you do something like a UDP, you'll need something that handles the big numbers.
I have two...one which handles the low numbers very incrementally and the other hits the big 250 number.
My $.02: Don't get the beam type, get the "click" one. I've had a "needle" torque wrench, and it never gave me confidence that it was accurate. Now that I have the "click" type, once I hear it click, is stop pushing (instead of watching the needle...did it reach the number? Give it another push...?
Also, I would buy the 1/2" drive and just buy an adapter. It should be stronger, and an adapter is <$5.
ha, I got mine from harbor frieght. Not really a tool I use daily. 4% is close enough for me.. and the price was right
http://www.harborfreight.com/cpi/cta...itemnumber=239
I use it mostly on the wheel lugs...
Obviously it doesnt compare to the craftsman tool in terms of quality.. But if you really doing life or death work with one, you'd really need to get them calibrated anyway.
Most of the Craftsman hand tools are great quality (and nice that they are backed by the lifetime warantee). However, not all are made by Craftsman, many are just other companies with the Craftsman name and a 50% markup stamped on them (ie: Gear Wrench).
If the increments are good on this one are small (ie: 1 ft/lb.) I might get it instead. I'll probably only use it for tires as well.
ummm, it's standard fare torque wrench.. as you turn the handle, you dial in 10's, on the part that turns are 1's... so you can dial in exactly. then you can lock it there by turning the **** at the bottom. Pretty much like many other 'clickers' I've seen. its a hefty tool, doesnt feel cheap. I'm not sure if I would use it to rebuild the internals of an engine, but for wheels/suspension, heck, I even use it for 25ft-lbs on my oil drain plug
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
![kiss](https://maxima.org/forums/images/smilies/kiss.gif)
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Originally posted by Rich96
Also check cummins and harbor freight. They have decent quality tools at good prices.
Coupon Codes for harbor freight if anyone is going to order this:
061-723-858 is for free shipping no minimum order, expires 7/1/2003
35233-0RVD is for free attache case + $5 off $29.99 min purchase expires 5/1/2003
445-567-199 is for free shipping + $5 off, $29.99 min purchase expires 2/1/2003
you may have to order by phone to use these.
800-423-2567.
800-423-2567.
I got the 1/2" microtork from craftsman. part # 944595, range 20 - 150 ft-lbs or 33.9 - 210.1 N-m. Think I paid $69.
Haven't had a problem. As for usage, that all depends how much you work on your car. Just think of it as a level of comfort that you tightened the bolts to the proper spec.
As for my regular usage:
- wheels (very important to me)
- FSTB
- oil pan bolt
SHIFT_woosh
- FSTB
- oil pan bolt
SHIFT_woosh
Originally posted by luckee2bhere
do you ABSOLUTELY need a torque wrench to put on the FSTB??
I just ordered a RSB and I'm getting a FSTB in the next day or so...
800-423-2567.
800-423-2567.
![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
I called for a status on my order and let me just say that the 2 people I spoke with were incompetent a-holes. I will never order anything from them again.
Also, they ship USPS so no tracking number for my order. I may have to tell them it never got to me (if it ever does) and demand a new one just for spite.
04-16-2020 05:15 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
