Varible Valve Timing??
Old Jan 5, 2001 | 01:50 PM
dvyuan
Does our 5th Gen have this on the VQ engines?
Old Jan 5, 2001 | 01:58 PM
Jeff92se's Avatar
I'm needing a caw
No, none of the usa VQ engines feature any type of valve lift or timing changing devices other than the stock cams currently residing inside the engine.
Old Jan 5, 2001 | 06:28 PM
blackmax2000's Avatar
According to Nissan we do have variable valve timing, but not lift. As far as I know the only nissan engine that has lift is the RB26DETT.
Old Jan 5, 2001 | 06:50 PM
Mike S.'s Avatar
UMM>>>>>>>.
As far as I know..the VQ35DE HAS a continously valve timing....unlike hondas on/off style. It also has a variable intake runner system. It does NOT adjust the lift. I belive its just on the intake cam where the New Z should have it on both I/E and whala.....300hp
The VQ30DE just has the variable lenght intake runners.
Old Jan 5, 2001 | 07:46 PM
Jeff92se's Avatar
I'm needing a caw
BlackMax. None of the VQ30 have varible timing or lifts. The 92-94SE VE30 have varible valve timing on the intake cam. See my sig, you can see it there.
Mike: If the 3.5 liter has varible cam timing, it better be pushing 280hp
Old Jan 5, 2001 | 08:17 PM
just telling you what was told from nissan and stillen and JWT...but they may not know that much about the VQ
Old Jan 5, 2001 | 08:24 PM
Jeff92se's Avatar
I'm needing a caw
I think you may have misunderstood them. You guys have varible length intakes and varible capacity mufflers. But that's it. Just put it this way, wait until they DO put that stuff on there!
Old Jan 5, 2001 | 09:16 PM
Maxmann's Avatar
This is on the 92-94 gen models, SE only. I've asked, and been told, this is not on the current models (i.e., 4th and 5th gen.).
Old Jan 6, 2001 | 04:53 AM
wdave's Avatar
That is correct - also almost all of those 92-94 SE's had to have the variable mechanism replaced at about 60k. Probably that's why they dropped it - be glad we don't have it.
Dave
Old Jan 6, 2001 | 09:33 PM
Loe max's Avatar
He is right. The 3.5L DOES have Variable Cam Timing ( Nissan Continuously Varible Valve Timing Control System ) or NCVCS. This information is straight out of the 2001 Nissan Pathfinder brochure.
Even though it only makes 240hp in the automatic form, the Variable Cam Timing is to broaden the torque band in the SUV.
Loe max's Avatar
Old Jan 7, 2001 | 12:56 PM
Mike S.'s Avatar
Jeff.....
They use the timing to help with low end. The new qr25de(new altima and sentra se-r) has it...the current base 1.8L sentra has it also. Its not ALWAYS for high hp applications. the 1.8 makes 127hp(decent) but not meant to be a si killer. BUT it makes 127ft-lbs of torque at 2400 rpm....not 6000+ like most vtec's. The idea is to give it good low end punch...not every soccer mom/econ box driver is gonna shift at 8K.
Also..the 3.5L VQ is obviosly easily "tuned". Its 240hp with and auto....250hp with a 5sp. The new z is gonna use this engine and should be pushing 300hp....same dispacement..now blowers.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
Apr 8, 2018 09:23 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
