Need Help! ASAP
Old Jan 20, 2003 | 04:45 PM
HitManSE's Avatar
Need Help! ASAP
Does any1 know were the exact location of the Idle air conrol valve is at on a 5th gen 2k max. damn thing keeps stalling like 3-4 sec after its started. thanx
Old Jan 20, 2003 | 04:53 PM
HitManSE's Avatar
Pulled the code P0505 with the scanner, it said idle air control malfunction. I dont have troubleshooter with 99 up cars so i cant pin point the problem. I would usually go on AllDATA and find this but we updadted to the DVD version last week and i still dont have the correct config code to install the program i checked my code book and all it has to say is IAC ACC valve? that helps me alot.
Old Jan 20, 2003 | 05:05 PM
HitManSE's Avatar
Bump, comon some1 has to know something about this.
Old Jan 20, 2003 | 08:12 PM
itdood's Avatar
Perhaps I shouldn't say anything since this experience is from a differenct car. I had an IAC go bad in my Talon. It was a stepper motor that the ECU uses to adjust idle. I suspect this is something similar? I simply used an ohm meter and checked the motor out according to factory specs. It was acutally OK cold but failed at operating temp. It caused low idle, sometimes high idle, stalling, surging.
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
