UNDER Drive Pulley and Subwoofers
Old Jan 21, 2003 | 03:36 PM
JBL85's Avatar
Hey guys, is it bad to run 3 12" subwoofers and a Under Drive Pulley at the same time?
One on left is aftermarket, one on right is stock part. So is it do-able with NO damage or it shouldnt be done because of damage?
Old Jan 21, 2003 | 05:37 PM
spta97's Avatar
I'm no expert, but I don't think any damage could be caused. From what I understand about the UDP is that it will decrease the power going to the alt by a slight amount. This would probably cause the amp to want more power and perhaps the bass would not be what you would expect. Most amps have a built-in low voltage protection so if that became an issue the amp would most likely be fine.
Please anyone else join in.
Old Jan 21, 2003 | 05:44 PM
JBL85's Avatar
Thanks for the info, my friend wants one in his V6 Altima and its a show car, so I am trying to figure out if we should install one in his car or not. Needs to stay reliable, I wont want his batterey dieing or alternator breaking.
Old Jan 21, 2003 | 06:02 PM
spta97's Avatar
I'd like to hear another member join in. I don't have first hand experiance with UDPs but pleanty with subs
Old Jan 21, 2003 | 07:04 PM
PoLo's Avatar
2-Wheelin it...
correct, a UDP would require the alt to pull more for the same power, therefore it's not ideal to be doing that on a system.
i'm setting up my system and i'd love a UDP, unfortunately you can't have your coke and sniff it too.
on the other hand, they are producing lightened pulleys that are the same size as stocks. this i'd like to question as to what it would do to the alt. and the power being drawn from it.
Old Jan 21, 2003 | 07:19 PM
BigDogJonx's Avatar
Look, this topic been discussed 1000+ times. SEARCH people if you dont believe me.
Lets take an example. I got 3 TVs in my car, PS2, XBox, 1000watt Orion Amp, plus other stuff. I dont have a problem in the world while driving the car. No dimming of the lights.
Dixit
Old Jan 21, 2003 | 07:26 PM
WildmanAL's Avatar
Get a power cap. That will supply your amp with the power it needs at those hard hitting base lines.
Old Jan 21, 2003 | 07:48 PM
LatinMax's Avatar
If you want a pulley that is lighter but the same size as stock go to this GD and get in on it.
85% of the power gain is from the weight of the pulley.
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Maxie40
Sep 14, 2015 11:28 AM
