Custom exhaust system
Old Jan 23, 2003 | 09:16 PM
02MaximaSE's Avatar
Im getting a custom job done to my 2002 max, im getting a custom B pipe made 2.5 inches in dia, from the crush bend pipe back to the stock muffler, and custom welded on. The resonator will be left on, im doing this until i can get my Y-Pipe in.
The shop is charging $90
Will i experience any gains? or any HARMFUL results?
thanks
Old Jan 23, 2003 | 10:20 PM
VMaximus02's Avatar
Re: Custom exhaust system
thanks
-I had that done when I had the exhaust shop installed my SFC's. The shop guy pointed out the restriction and recommended that I should do the work. I was convinced when saw the crush bend pipe, located right after the B-pipe resonator. I got it done for only $40. It is much cheaper than buying an aftermarket B-pipe. I did notice a better throttle response afterward. No addition noise or any problem so far.
-You should do it but ask him to lower the price, say $60?
Good luck!
Old Jan 24, 2003 | 06:33 AM
02MaximaSE's Avatar
Re: Re: Custom exhaust system
Good luck!
damn $40!!!!!! Im goin to low ball the price now!! thanks !
Old Jan 24, 2003 | 11:23 AM
2k2max's Avatar
Re: Re: Re: Custom exhaust system
I heard that the most restrictive piece is the b-pipe, not the y-pipe. Someone said in another thread that only having the b-pipe should yeild the same gain as having both a y-pipe and b-pipe.
does this make sense?
Old Jan 24, 2003 | 01:48 PM
02MaximaSE's Avatar
Re: Re: Re: Re: Custom exhaust system
Really? Has anyone dyno'd without a y pipe and just the b section changed?? With resonator on or off? Anyone have any insight on this? thanks
Old Jan 24, 2003 | 03:07 PM
2k2max's Avatar
Re: Re: Re: Re: Re: Custom exhaust system
Larry was the first to install the Warpspeed.
I don't think he dyno'd with just the b-pipe but he did mentioned in one of his post that he did not feel (butt dyno) any difference with just the y-pipe, but the did when he also added the b-pipe.
http://forums.maxima.org/showthread....5&pagenumber=2
Mar 12, 2020 12:06 AM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
