When to change coolant??
Old Jan 24, 2003 | 08:02 AM
Slothead's Avatar
The manual only says- Check
I heard aluminum blocks don't need coolant change as often due to less crrosives in system. Does anyone really know when to change the stuff?
Old Jan 24, 2003 | 08:34 AM
djmaxski's Avatar
I think I recall that under normal conditions the first coolant change isnt really necessary until about 60000 miles.
Old Jan 24, 2003 | 08:36 AM
AdamK's Avatar
60k / 48 months allthough some people have had the need to do it sooner... http://forums.maxima.org/showthread....change+coolant
Old Jan 24, 2003 | 12:40 PM
Green 2kSE's Avatar
Yep, I would check it earlier than 48mos/60k for sure. When doing a replacement, don't go by the color. Prestone and Zerex are green but they contain both phosphates and silicates. The Japanese coolants, whether red (Toyota) or green (Nissan, Isuzu, etc) all contain high amounts of phosphates but no silicates. The extended life coolants (Dexcool, Prestone extended life) are based on OAT that has no silicates or phosphates but you have to clean the system completely and make sure it's not exposed to air or you'll get brown sediments. I would just buy the Nissan coolant for a few extra $ and be done with it.
Old Jan 24, 2003 | 01:46 PM
foodmanry's Avatar
Da Roller Coaster!
Brown sediment in the coolant itself? Or in the system if it's exposed to air? Curious because I want to use an extended coolant in my Max.
Old Jan 24, 2003 | 02:08 PM
karguy's Avatar
I did research on the contents of various antifreezes. I went with Peak Extended Life Antifreeze. I used a 50% mixture of water to antifreeze plus 8 ounces of Red Line Water Wetter. This particular antifreeze contains no silicates, no phosphates, no borates and no nitrates. It is ethylon glycol based. It was only $7.50 a gallon and there was a $2.00 rebate per gallon. I was initially going to go with Nissan antifreeze but the dealer wanted $16.50 plus tax per gallon. That really bugged me on principle and that is when I started doing research.
Old Jan 24, 2003 | 02:46 PM
foodmanry's Avatar
Da Roller Coaster!
What is Red Line Water Wetter and what is the purpose? I have never heard of it. Is it a coolant system conditioner?
Old Jan 24, 2003 | 02:59 PM
karguy's Avatar
Water Wetter improves the efficiency of your coolant to cool your engine! Think of it as increasing the amount of heat your cooling system will be able to eliminate!
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
