Changing the Brakes
Old Jan 24, 2003 | 04:29 PM
'02 Style's Avatar
Changing the Brakes
Can someone tell me if a special tool is required to reset the brake caliper on a 2k2? I used to change my own brakes on previous cars, but then some started requiring a special tool to reset the caliper. Is this true for the Max?
Old Jan 25, 2003 | 09:47 AM
MichaelAE's Avatar
Re: Changing the Brakes
The front caliper piston can be pressed in with a c-clamp easily. The rear piston requires a clockwise turn to compress the piston. Some folks use a pair of needle-nose to do this, but you can buy a tool, like you're referring to, that attached to the end up your ratchet that makes it much easier. Sears sells this tool for $12 and it has patterns for about eight different styles of caliper.
Old Jan 25, 2003 | 09:54 AM
'02 Style's Avatar
Thanks!!! That was the info I needed!
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
Johnny9595
Sep 16, 2015 07:20 PM
toyoking
Sep 16, 2015 07:05 AM
bbsitum
Sep 11, 2015 04:55 PM
