Just got new front brakes and this...
Old Jan 25, 2003 | 11:48 PM
floridabornmax's Avatar
Is it normal for there to be a grinding noise on my brand new front brakes right when I am about to make a complete stop? It doesn't do it the whole time just when I am about to make a complete stop.
Old Jan 26, 2003 | 12:06 AM
2kSeattleMax's Avatar
Do you have slotted rotors? If so, yes. I upgraded to a precisionbrakes kit with 13" rotors and willwoods. They can get pretty noisy. They do stop on a dime though!
Old Jan 26, 2003 | 03:40 AM
irvine78's Avatar
nosier than stock brakes, yes. but even slotted rotors should not make 'grinding' noise...
check the rotor surface for any rubbing..if something is making contact with your rotors, then you'll be able to tell from there first.
Old Jan 26, 2003 | 07:39 AM
itdood's Avatar
The pads aren't seated yet and have rough areas still, so that might be it. It's also normal to require a bit more pedal for stopping power until the pads seat as well.
Once they seat it shouldn't though, takes a couple hundred miles for break-n.
I put slotted rotors on a different car and those weren't noisey at all. I think this all depends on the pads and how rough they are when they're new. But it could also be a problem with install, you'd be surprised how the simplest things are overlooked and cause strangeness.
Old Jan 26, 2003 | 09:54 AM
Oh thanks. So I guess I should wait a few weeks to see how they work.
Old Jan 26, 2003 | 11:45 AM
Check to make sure you have all your washers in place on your mounting brackets. I missed a washer during one of my installs (1/18"), and it caused a bolt to contact the surface of the rotor. A physical ispection should tell you if you have anything out of whack.
I do notice that the pads make noise as the brakes are being applied since they are held in with cotter-pins.
Old Jan 26, 2003 | 11:56 AM
Shouldnt it stop making noise after a few weeks?
Old Jan 26, 2003 | 12:32 PM
With my case, the pads metal backing can be heard as it slides through the caliper. Kinda a click sound.
Old Jan 26, 2003 | 12:54 PM
Is that normal?
Matt93SE
May 24, 2019 02:58 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
