Y-Pipes
Old Jan 31, 2003 | 05:22 PM
Motownmax's Avatar
Y-Pipes
I'm sure many of you have already answered this question and/or been a part of a thread in the past that related to this subject, but I need some advice regarding Y-pipes. I have a 2k1 SE with most of the simple bolt ons. Greddy Exhaust, Stillen Intake, Underdrive Pulley, full suspension, etc. etc. One mod that I always wanted to go with, but was hesitant was the y-pipe. Once installed, does the check engine light stay on. And if it does, do I need a chip or recal the ECU? I keep getting different answers from people I speak to, so I thought not ask the pros at this. Thanks.
Old Jan 31, 2003 | 06:14 PM
foodmanry's Avatar
Da Roller Coaster!
Re: Y-Pipes
Binding that you have the correct y-pipe for your car (Cali or Fed spec), all O2 sensors were handled with car, and you disconnected the battery (positive and negative terminal), and installed everything correctly then the SES light should not come on at all.
Old Jan 31, 2003 | 06:20 PM
Motownmax's Avatar
Re: Re: Y-Pipes
Thanks for the info. Is there a difference in the pipe that I order? Do I need to call out for a Cali or Fed spec? I live in Michigan and was leaning towards the Cattman. Any thoughts?
Old Jan 31, 2003 | 06:25 PM
foodmanry's Avatar
Da Roller Coaster!
Re: Re: Re: Y-Pipes
Yes the placement of the 02 sensors are different. Also I believe the length is a bit different as well. Cattman is an excellent y-pipe especially for a winter area like Michigan.
The easiest way to see if you have a Cali or Fed spec car is to open the hood and facing the engine bay from the front of the car there are 3 or 4 plugs on the front of the engine right behind the radiator. If you have 3 plugs, then you have a Fed spec car, if you have 4 plugs then you have a Cali spec car.
Old Jan 31, 2003 | 06:50 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Re: Re: Y-Pipes
all 2k1s are cali spec. the 2k's are a mix of fed and cali spec.
Old Feb 1, 2003 | 09:26 AM
foodmanry's Avatar
Da Roller Coaster!
Re: Re: Re: Re: Y-Pipes
Oh yeah...I didn't pay attention to that in his original post. You got Cali spec for sure then!
Old Feb 1, 2003 | 12:42 PM
Desert Pearl's Avatar
If you check out my Maxima site, you can see pics of the Stillen Y-pipe. It's a two piece design in which you use both pieces if you have a Fed spec (which you don't), otherwise you use just the rear section. You could always do a conversion like I did if you want to use both pieces. Either way, the Y-pipe is the biggest performance upgrade you can do (excluding nitrous & forced induction that is). Also if you visit my site, don't be scared of by my comments on the loudness of my Stillen/Greddy exhaust combo. That was using only a Greddy muffler with custom piping and a different resonator... not the system that you have. Happy Modding!
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
