Anyone install a K&N filter intake?
Old Feb 6, 2003 | 09:25 PM
thomasd cook's Avatar
Need some pointers for removing old intake and installing new K&N filter with a bracket that the filter is on and a bar. Please help or direct me to a how to page. Thanks.
Old Feb 7, 2003 | 03:56 AM
Virus's Avatar
www.frankencar.com and make sure to get the Apexi dry filter. We have wussy MAF's and the K&N oil wetted gauze filters can screw them up.
Old Feb 7, 2003 | 07:05 AM
foodmanry's Avatar
Da Roller Coaster!
Re: Anyone install a K&N filter intake?
Are you talking the Stillen intake? Or just a K&N filter universal element?
Old Feb 7, 2003 | 07:12 AM
y2kse's Avatar
And this is precisely how rumors and misinformation get started. Look here if you want the facts:
http://www.knfilters.com/faq.htm#6
Old Feb 7, 2003 | 07:15 AM
jjs's Avatar
jjs
33,000 miles on a K&N drop in, already self-serviced once...
and guess what....
NO PROBLEMS.
Old Feb 7, 2003 | 07:29 AM
LouE37's Avatar
Thank you for clearing that up. The oil if anything would clean the MAF hot wire. When your MAF goes its because you have a bum MAF...not because of over oiling your filter.
Old Feb 7, 2003 | 10:30 AM
Virus's Avatar
Ok, maybe I should have put it another way. Most of the people here on the org that have had blown MAF's use K&N filters. When they take the cars to the Dealers, most of them were not replaced under warranty because the Nissan Techs said it was caused by the oil. While K&N may very well be correct, there is an old adagy:
I can't make you, but I can make you wish you had!
Old Feb 7, 2003 | 10:41 AM
jjs's Avatar
jjs
Not quite true still...
http://forums.maxima.org/showthread....t=maf+and+poll
http://forums.maxima.org/poll.php?ac...ts&pollid=1086
as can be seen, there is often an EQUAL number of MAF's that take a nosedive with NO change in filtration choice.
Old Feb 7, 2003 | 10:51 AM
Igor911's Avatar
How do u clean the dry filter? Do u need to spend 70bux on a new 1 every 2 oil changes?
Old Feb 7, 2003 | 10:54 AM
Re: Re: Anyone install a K&N filter intake?
I'm talking about a K & N filter universal I guess. I bought the kit from E-bay for about $70. It came with a filter, an adapter, 4 screws with nuts and a bar with holes in it and a small curve on one side. I took out the old factory box and put the filter on. The only deal is that it hangs and I'm sure this bar has something to do with holding it up but I can't see where it bolts to(supposed to bolt into an existing hole I believe) and where it supports the filter itself. Thanks for any help.
Old Feb 7, 2003 | 11:01 AM
y2kse's Avatar
Touche!
jjs's Avatar
jjs
Touche!
Thought you might like that one!!
Old Feb 7, 2003 | 11:02 AM
y2kse's Avatar
www.knfilters.com
Old Feb 7, 2003 | 11:05 AM
Igor911's Avatar
www.knfilters.com
That doesnt have apexi filters....thats the k&n site.
Old Feb 7, 2003 | 11:09 AM
jjs's Avatar
jjs
Not sure if this answers the question, but it looks like you don't...
hmmmm.....
http://www.mkiv.com/techarticles/filters_test/2/
Old Feb 7, 2003 | 12:49 PM
y2kse's Avatar
hmmmm.....
Oops. My bad. I thought Igor911 was asking about cleaning K&N Filters.
You're right, of course. The filtering material used in the Apexi air filter cannot be cleaned. So the Apexi filter is expensive, requires additional hardware to mount, and has to be replaced every time it gets dirty . . . the best of all possible worlds.
Old Feb 7, 2003 | 02:10 PM
Virus's Avatar
I digress. My personal preference is the Apexi. It's a better made filter, but it does cost for that craftsmanship. It filters much better. It adds a couple of extra ponies which truly don't amount to much.
Old Feb 7, 2003 | 02:31 PM
y2kse's Avatar
True, true. From the standpoint of filtration alone, there's no doubt that it's one of the best high-performance air filters available on the market.
cruce91
Sep 20, 2015 10:23 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
95Maxi
Aug 29, 2015 09:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
