Radio cleaning
Radio cleaning
Can someone please tell me how to clean the stock radio. I mean the am/fm buttons etc. When I clean the car I wipe it down with a damp rag but as of late the white has been looking dirty. Someone help.
Re: Radio cleaning
This will work...
Be very careful, and try a small spot first, but use Fantastik or 409 on the white lettering. It cuts through everything and should not actually remove the lettering. I've done this before on other things and it works very well. I'm not sure alcohol will cut through dirt.
BTW... what are those things on your front fascia and how did you do it?! It helps to break up the slab look to the front (at least in the photo). Also, does not look tacked on or rigged.
Good Luck!
Good Luck!
Re: Radio cleaning
Alcohol may be too harsh for the plastic.
Re: This will work...
Good Luck!
Good Luck!
fx4five
Oct 1, 2015 04:58 AM
