Off Center Rotor ???
Old Feb 8, 2003 | 04:08 PM
raiderttu's Avatar
I have a 2000 SE with 75K miles and decided to replace the front rotors and pads with the slotted rotors from the 4 for 200 forum deal and some axxis metal pads. I used the advice of the numerous postings in the 5th gen forum and made sure I didn't forget anything. Everything went smoothly, I cleaned all the parts and greased in all the appropriate areas and even torqued all the bolts to spec even the wheel lugnuts. I took the car out for a spin to break them in correctly and noticed that I have some very bad brake judder. The front end even vibrates slightly when I don't use the brakes. So I thought I did something wrong. I took everything apart and checked for something out of the ordinary and could find no problems. So I put everything back together and even sanded the pads so that I could try to rebed them onto the rotors. I took the car out once more and the car vibrates like hell. Could the rotors be off center somehow? Any advice? Even if you could point me to a previous post I would much appreciate it.
jt
Old Feb 9, 2003 | 02:37 AM
raiderttu's Avatar
Problem with Rotors or pads.
Nevermind I found the thread.
http://forums.maxima.org/showthread....ght=rotor+deal
Old Feb 13, 2003 | 09:39 AM
raiderttu's Avatar
It turns out all I had to do was turn the brand new rotors and everything was fine. Has anyone else had to do this with these rotors?
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
Socalstillen
Sep 26, 2015 12:01 PM
