Where can i get sub level or volume control??
Old Feb 9, 2003 | 11:45 PM
skyjay617's Avatar
guys, my friend has installed an amp on his headunit with preamp outputs BUT NO SUB CONTROL, so they volume of the woofer is really quiet. A guy told me i can get him a sub level or volume control. anyone know where i can get one?
thanks for any advise
Old Feb 9, 2003 | 11:51 PM
Uconn411's Avatar
You just can't adjust you're gain? I know radioshack has a volume control for 8ohm home speakers, it about $14. Don't know if they make a lower ohm model though.
Or maybe a crossover:
http://www.etronics.com/listproducts...24&image1.y=18
Old Feb 9, 2003 | 11:57 PM
skyjay617's Avatar
so they have like 4 female RCA plugs?
Old Feb 10, 2003 | 12:04 AM
Uconn411's Avatar
No, the ones at radioshack won't have 4 rca's. Probably have to go with a crossover. I'm no audio expert, so hopefully someone else can offer advice.
Old Feb 10, 2003 | 07:26 AM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Where can i get sub level or volume control??
The only reason you would want an external volume control is to adjust the level of bass, not to increase output.
There could be a million things wrong. Check the gain levels on the amp. If that doesn't help, take it to a stereo shop.
Old Feb 10, 2003 | 10:19 AM
D Love's Avatar
I believe that what you are looking for is something like this: remote bass controller Now, this might not work for your specific application, since you might not have a PG amp, but you could probably search for something similar for your amp if it is in fact what you are looking for. You might also want to try Best Buy, or some stereo shop in your area.
Old Feb 10, 2003 | 10:25 AM
2kSeattleMax's Avatar
Your friend is in a tough spot. Some amps have gain adjustment via LPL like the link above. Typically, you have to buy the model which supports it (Phoenix, MTX, Kicker or Infinity). Others have SUB out on their head unit where the gain can be adjusted from within the head unit (Kenwood, Alpine, etc).
There is a product called "Epicenter" which does what you are looking for.
http://www.audiocontrol.com/caraudio.htm
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
