Top Speed in 3.5 Automatic?
I was just wondering what's the top speed for a 02-03 Maxima 3.5 SE Automatic. The 01 Brochure says an SE equipped with 17 inch wheels can go 143 MPH. 3.5's must be able to go faster than 3.0's, even Automatics.
Re: Top Speed in 3.5 Automatic?
What are the factory tires rated at? That could be the source of the published top speed rating.
Think there are some posts on this very issue. Some people were buying aftermarket items (ApexI RSM or GTECHs??) that remove the limiter.
This might be discovered through a properly formed search.
GLE - just shy of 130, SE - 149 (145ish drag limited). i don't recall if there was any info for auto SE's.
Re: Re: Top Speed in 3.5 Automatic?
Originally posted by sloppymax
that 143 on the 2k1 is for 5spds. the auto top out at 128, with the high level of speedo error at that speed, its hard to tell how accurate it is. i could be wrong and if i am, then im sure ill be corrected but i think the 2k2 have similar if not identical top speeds. not to say there isnt room to go faster but you will need a rsm to do it.
http://forums.maxima.org/showthread....hreadid=181988
I've done easily 130, but let the gas go... i could have pushed it more, but got hesitant and slowed right down, and a bit later saw a tropper on the side of the highway, i had the tropper instict i gues... close call and yes 2k2 aut0...
I believe that Kloogy is the only one to answer your question. I have to agree with Kloogy. I have gone up to 130 in my 02 Maxima 3.5 SE Automatic , but it just wouldn't go any faster than that. I'm pretty sure that this has been the subject of another thread also, and they came up with the same result.
Several people have also said that they CAN'T go above 130 in an SE though - wonder if this is a Cali spec or Canadian spec thing...? Or did they just happen to have a strong headwind (or me a strong tailwind) that day?
Re: Re: Re: Top Speed in 3.5 Automatic?
Originally posted by bk2kmax
Wrong, the 2k Max will top out at 130 in auto trim. The SE has a different top end based on the tires and the removal of the speed limiter, it is drag limited to 143.
Originally posted by Maximax2
Don't think so - when I checked with Nissan they said they limit the speed to the tires' speed rating - 149 on an SE, 130 on GLE / GXE. And several people, including me, have taken their SE's above 130.
Originally posted by kloogy
Im telling you guys , I have an SE Auto. I know that Irvine78 told me if I get the Apexi S-AFC ( I think thats what it is ) it tricks the computer and you can go faster. The 2k2 auto SE CAN go faster, but it is limited. I have never pushed a 6 speed to that limit, so I can only speak to the Auto SE .
I don't know how everyone came to the numbers, I know that I hit 140 in my 2001 GXE automatic. The limiter kicked in there and bought me back down to 135 and then back up to 140 and then back down again, and so on until I got bored of it.
OK For all the auto 5th gen maximas sayin they hit over 130 without a rev speed meter are either 1: full of $hit 2: you have some terrible speedo error. I have a 02 SE Auto and have hit 130 and will not gain anymore but it doesn't cut you back like some of the other guys are saying in the 00-01 autos. This is facts guys for all you other autos sayin you have top over 130 need to get your speedo checked.
Matt
Matt
Matt
Matt
Matt
Matt
Has it occurred to you that just because your car acts that way, that maybe it's not indicative of ALL 5th gen autos? And that those of us who have hit well over 130 feel the same way about your info?
The only fact in your post is that your auto can't go over 130 - fine. Other facts include some of our autos going 130+, plus Nissan, C&D etc. stating that the SE is NOT limited to 130.
Not trying to beat you up, you're as entitled to your opinion as the next guy (or me). But there's as much (or more) evidence on the other side.
You're still a cool guy tho
Matt:
Matt:
Matt:
Matt:
as i said again, 2k2 autos are limited to 130. 6 spds are DRAG limited to 149 mph. as someone mentioned before it is the tire ratings. even if you have a rev limiter whatever you call it. you will never pass 149 mph. i say again, NEVER. your gonna ask me why? cuz its drag limited. the engine can pull more, but the car won't.
btw, blubyu2k2, i thought you had a 6 spd this whole time. did you get your MAF sensor fixed yet? is that what its called? i forgot.
Are there any TSBs out there for defective speedometers in the 2K2 Maxima?? (rhetorical question)
Just curious, because I have reached a speedo indicated speed of approx 143mph while running against an Acura TL-S on the NJ Turnpike. Hitting the speed governor is like hitting a wall (sort of); you hit the max speed, the fuel is cutoff until you drop about 5mph and then you re-engage. This didnt happen to me.
I've driven cars while working my parttime job (Hertz - vehicle transporter) where I've hit the speed governor on various cars and this DID NOT occur with my 2K2.
And as far as the fountain of misinformation in this link (http://nissan.jbroadtests.com/Maxima/2002/index4.php),
how are they getting a 14.9 at 95.6 1/4 mile time??? If I could trap that high, I'd run a 14.5 not my own 14.7 and especially not the as tested 14.9?!?!?
Factors...
I just wonder when people post their top speed, what is it based on, speedometer reading? And what tires do you have, some stock, others different aftermarket, right?
It is well known that the real speed is ALWAYS below the speedometer reading, when all in stock configuration. The laws prohibit speedometers to be by any value too low, but too high is OK. Usually, the speedometer reading is wrong up to 10%. For Maxima, it is likely to be about 10mph for 130mph speed. You see 140mph, but it is well below.
The other thing is different tires. If you decrease the diameter of the tire by 3%, that would make 5mph error in speedometer reading at the top speed.
if you have a link to nissan or c&d stating the auto 2k2 top speed limiter is higher than 130 then please show me. c&d didnt even test a 2k2 auto, it was a 6spd and it was drag limited at 145, per their website.
Why would you think an auto would have a speed limit if you believe a 6-speed doesn't? Because some random site says "ca. 130" (which, from what I can tell, means "estimated")?
Listen, if you guys think they're speed limited - fine. I personally believe what I've been told by Nissan, read in tests (please don't tell me again that autos and 6-speeds have diff limits), and done myself. What's the diff - if you're right, 130 is damn fast. And I'll never see 149 (can't imagine the road where I could do that), so it's probably immaterial. Besides, I'd probably have to hit 170 to convince you guys it's not speedo error...
Here are some links that show SE's (4th gen, and two flavors of 5th gen) hitting 140+, BTW (yes, I know, they're 6-speeds...):
http://www.caranddriver.com/xp/Caran...axima&class=44
And your reasoning for this is because while the 6-speed SE's can handle the top speed, the autos have the different suspension, tires, and aerodynamics so they need to be speed limited. Oh wait - no they don't...
Originally posted by cwerdna
I don't think it's entirely impossible (at least w/a manual). It's not clear if those figures are from a manual or auto but it looks like the former since they tried to list 6 gear ratios w/NA next to each of them. With my stock 2K2 GXE auto I've run 14.908 @ 94.32 and 15.009 @ 94.39 before.
And believe or not, the trap difference between 94.39 & 95.6X is pretty sizeable when it comes to the auto 2K2 Max. 95-96 mph traps are normally associated with a 6speed Max (or a modded auto 2K2), tripping the lights @ mid-low 14s NOT 15-flat.
Peace.
Facts from Nissan on 2k auto GXE= 130mph
2kSE=142 drag limited
I looked in my old brochure when I bought my Max and those are the figures, I've personally only seen 130 in my GXE Max and I could feel the speed limiter kicking in which bumped the speed back down to between 128 and 130, so I'm going with 130.
I doubt anyone has done 140 in a 2kGXE auto unless you have the speed limiter removed. I'm not saying it isn't possible, I'm saying I doubt it will hit 140 in the 2kautogxe.
I agree with blubyu
I agree with blubyu
worked for Nissan
When the 00 Max came out I worked for Nissan at the time as a tech, and shortly after I quit and went working for Audi- more $$. The SEs with 17" tire combo and 5spd tranny have no speed limiters. The speed limiter is set at 130MPH on all other cars, auto and 5spd. When U reprogram a ECU on a Max 5spd, it asks U if the car has H or V rated tires. All 5spd 01 Maximas have the same ECU, now automatics have diff ECUs- depending on trim level, power seats, sunroof,climate control, tracion control, etc. I had my GXE reprogrammed with a V-Rated program, before that it would hit the speed limiter at indicated 135MPH like hitting a rev limiter in 1st gear almost at WOT. Its pretty voilent when it kicks in. Now without the limiter I have seen 155MPH on the speedo with tach pretty close to redline- I have all the bolt ons and some other goodies- its NA, non NOS, 5spd GXE with LSD
)) Working for Nissan has its bonuses. As for 02-03 6spds, I see a guy on 355 all the time in one, I should run him and see if his cuts off at 130 or pulls to about 145ish- sounds like its moded so it might pull more than that. Now my SE-R pulls to 172MPH if ya care :P
Matt
Matt
