3.5 Max SE vs. 3.5 Altima SE (both auto).. which is faster?
Old Feb 16, 2003 | 10:32 PM
PeterUbers's Avatar
A friend has a black 3.5SE auto and wants to run w/ my 2k3 SE auto ... anyone have any experience that they're willing to share w/o yellin' at me to use the search fxn??
Old Feb 16, 2003 | 10:38 PM
slickrick's Avatar
Re: 3.5 Max SE vs. 3.5 Altima SE (both auto).. which is faster?
its a drivers race. just get a good launch.
Old Feb 16, 2003 | 10:50 PM
cwerdna's Avatar
I agree w/slickrick. I think it'll come down to reaction time and launch.
I've drag raced (at at a track) a 2K2 Altima auto V6 w/intake and the Altima got a slightly better 1/4 mile, but I won (reached finish line 1st) cuz of better reaction time.
Old Feb 16, 2003 | 11:05 PM
AzNx2k2xSEXima's Avatar
i've lost to my friend....by a headlight though....i only have a stillen intake and 10k more miles....i had a bad start though....and a set of BALD *** tires.....seriously....if you do the penny test w/ lincoln upside down, my tread barely touches his hair....oh...we went to a 100
Old Feb 17, 2003 | 03:40 AM
wild willy's Avatar
You should fear the fastest FWD production car ever tested
I think there are several factors that come into play.
1. Driver
2. Driver
3. That stupid throttle by wire....who's ever car decides not to choke and fall a sleep for a second to 2 will be the winner
Old Feb 17, 2003 | 06:11 AM
92 SE-R 02 SE
I think we all should fear the SRT-4 Neon
Old Feb 17, 2003 | 06:17 AM
Hraesvelg's Avatar
Isn't the Altima lighter? That's what my dealer said...
Old Feb 17, 2003 | 06:35 AM
Virus's Avatar
Totally a drivers race, but as mentioned before, one choke from the throttle by wire and it's over. I've had the Max choke several times, but since I put the UDP and Midpipe on I haven't had the problem. Could just be coincidence. I beat an Altima at the track, but I got a slightly better launch and it was so close only the timeslip dicearned the winner.
Old Feb 17, 2003 | 06:55 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
That's not funny But it sure is going to be true
Old Feb 17, 2003 | 07:44 AM
slickrick's Avatar
until after 20k miles when the dodge breaks down.
Old Feb 17, 2003 | 08:32 AM
Jaws's Avatar
Pretty small weight difference (~80 lbs if I remember correctly). Driver's race.
Old Feb 17, 2003 | 08:56 AM
F23A4's Avatar
In line with the question I posed on Altimas.net last week, I have yet to see a stock auto 3.5SE run 14s. Whereas, I've seen several auto 2K2 Maximas (inc. myself) run 14s consistently.
Peace.
Old Feb 17, 2003 | 09:21 AM
03BlkSETE's Avatar
Bald tires would be better in a race in dry road conditions. There is more tire making contact with the road. Slicks have no tread.
Old Feb 17, 2003 | 10:54 AM
Linh's Avatar
are you kidding?
Old Feb 17, 2003 | 11:13 AM
pjonkheer's Avatar
The Altima is a mere 50lbs lighter. In any case, a non issue... This race comes down to two different factors...
1.) Driver
2.) Tires
Let's face it. Both cars are dead even. The extra 15 horses on the Max will only be noticed above 80mph...
Old Feb 17, 2003 | 11:47 AM
wild willy's Avatar
Originally posted by Linh
are you kidding?
He may not have seen it..but, I sure hope he has read it somewhere...Like every car mag
F23A4's Avatar
are you kidding?
not!
Old Feb 17, 2003 | 12:16 PM
xfirepwr1's Avatar
Make sure u manually shift at 6500 RPMs and you should be fine. Brake torque your car at about 2000RPMs and makes sure u dont spin the tires too much. It makes a lot of difference between keeping it in D and manually shifting, and Im speaking from experience.
Old Feb 17, 2003 | 12:33 PM
slickrick's Avatar
Re: Re: 3.5 Max SE vs. 3.5 Altima SE (both auto).. which is faster?
how much difference? i just usually keep it in 3rd.
Old Feb 17, 2003 | 12:37 PM
Hraesvelg's Avatar
What is "brake torque" ?
-Jeffrey
Old Feb 17, 2003 | 12:41 PM
OT n00bs FTMFCSL
Re: Re: Re: 3.5 Max SE vs. 3.5 Altima SE (both auto).. which is faster?
-Jeffrey
Keep the brake on (using your cars torque converter)while spooling the engine up to your desired RPM. That way when you launch all the available power is transfered to you wheel/wheels. Check out the how things work web site and see how a torque converter works. Helps you understand a bit better.
Old Feb 17, 2003 | 12:42 PM
xfirepwr1's Avatar
Big difference. When u keep your can in D it shifts at 6200 RPMs and whey u Manually shift u can pull it all the way to Red line, just make sure u shift at abouty 6300 because its takes a fraction of a second for the computer to change the gear and it will shift right at 6500. Mess around with it.
Break torque is when u hold the brake and gas pedals at the same time. U rev your engine to 2000-2500, and then when u release the brake pedal the car pulls harder, maker sure u dont press the gas pedal all the way, juust half because u will spin your tires and loose for sure. Try it few times at a stop light and get the feeling of it.
Old Feb 17, 2003 | 08:00 PM
SR20DEN's Avatar
VQ Wizard
1.) Driver
2.) Tires
The weights are identical. Nissan advertised the Maxima as having a one pound weight advantage over the Altima. However the weight will differ slightly depending on the configurations of the cars.
As for the 15hp.... there is no extra 15hp. This has been proven in the real world about a hundred times over.
Therefore we're left with... same hp, same weight and slight suspension differences between them (speaking of stock to stock comparo). Nine times out of Ten it will boil down to the launch which is about the only thing that requires any sort of skill in an auto for drag racing.
Also I assume you mean 'quicker' when you said 'faster' and are speaking of a run of the mill drag race and not all out top speed. In which case I am inclined to believe the Maxima would have a slight advantage. Anyone got any total cd and surface area numbers?
Old Feb 18, 2003 | 11:11 AM
CHAZMAX's Avatar
One of my first races (in my auto 2k2) was w/ auto 3.5SE. It was very close, but I came from about 1 - 1 1/2 car lengths behind and beat him by about another car length. Granted we were at about 110mph from a rolling start. And my girlfriend was in the car. He had no passengers.
Bottom line:
Just as it's been said before... They're real close. It comes down to the driver and maybe tires, etc. But I do believe the Max is (slightly) the faster of the two.
Knowing that... get a good launch down, and you'll get em'!
Old Feb 18, 2003 | 03:11 PM
F23A4's Avatar
Kinda like Car and Driver
http://www.caranddriver.com/xp/Caran...issan%20altima
1/4: 15.6 @ 91 mph
keep in mind, you brought up the magazine thing.
Old Feb 18, 2003 | 03:26 PM
wild willy's Avatar
1/4: 15.6 @ 91 mph
LoL..Wow..those are great numbers They had Hulk Hogan in the trunk with his girlfriend...they left that out of the article...
Old Feb 18, 2003 | 03:59 PM
MONTE 01&97 SE's Avatar
I think the Max has the edge slightly, I have ran across a few of them and had about 1/2 car length on them each time. I am even got a bad launch once and ended up ahead by 70mph.
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Sep 8, 2015 02:36 PM
jfl330
Sep 4, 2015 01:44 PM
DrVee
Sep 4, 2015 12:18 PM
coasterswim
Sep 2, 2015 07:43 AM
