Why can't I hit 6600rpms in 1st w/ "D" in my 2k3 auto?
Old Feb 23, 2003 | 10:59 PM
PeterUbers's Avatar
Is there a fix (yeah yeah, i searched already, so spare me the @##)
Old Feb 23, 2003 | 11:16 PM
andrew3616's Avatar
You probably cant hit 6600 because the ecu tells the tranny to shift before that. If you want to hit 6600 leave it in 1
TimW's Avatar
The silent but deadly Moderator
dirty little ECU secret. at least on the 2k/1. You cant hit the published max HP/rpm with the shift points we have. I suspect its the same way with 2k2+?
Old Feb 23, 2003 | 11:17 PM
andrew3616's Avatar
The max horse power in a 3.5 engine is at i think 5400 rpm. So why would you want it to shift at 6600?
Old Feb 24, 2003 | 12:06 AM
Larrio's Avatar
The Definitive AE Master
where did you find that stat? Mag statistics don't count
Old Feb 24, 2003 | 07:03 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Because your info isn't correct
Old Feb 24, 2003 | 08:39 AM
BioMaxDDS's Avatar
SteVTEC has spoken
Old Feb 24, 2003 | 09:03 AM
AKM2k5's Avatar
Dont know why you cant go that high in D, but I have been able to redline on D 90% of the time.
Old Feb 24, 2003 | 10:52 AM
Maximax2's Avatar
Re: Why can't I hit 6600rpms in 1st w/ "D" in my 2k3 auto?
Mine shifts early too; a few .org members have said their's shifts later (or at redline), so EDIT> that could be variation within the norms, or the ECU modifying behavior (i.e. if you do WOT shifts in 1st all the time, the ECU will start moving to max performance behavior - pun intended)...or even incorrect tach reading... <EDIT
Old Feb 24, 2003 | 12:07 PM
PeterUbers's Avatar
Re: Re: Why can't I hit 6600rpms in 1st w/ "D" in my 2k3 auto?
Originally posted by Maximax2
Mine shifts early too; a few .org members have said their's shifts later (or at redline), so either that's just variation within the norms, or the ECU modifying behavior (i.e. if you do WOT shifts in 1st all the time, the ECU will start moving to max performance behavior - pun intended).
You sure about this? I've never heard of a shift-point adapting ECU... What's your source of info?
Old Feb 24, 2003 | 12:46 PM
xfirepwr1's Avatar
Originally posted by BioMaxDDS
SteVTEC has spoken
Someone is Steve's a$$
j/k
Old Feb 24, 2003 | 02:13 PM
Nismo87SE's Avatar
Outside of manual shifting yourself no. That is unless you want to design a circuit that offers outside control of the shift soleniods. Even then you'd have to operate that with a switch or lever. I guess that is the price auto tranny drivers have to pay .
Old Feb 24, 2003 | 04:41 PM
Maximax2's Avatar
Re: Re: Re: Why can't I hit 6600rpms in 1st w/ "D" in my 2k3 auto?
Sorry, in my post I was suggesting possibilities - should have specified that.
However, the transmission shift control is electronic, right? (once had to "reboot" my '95 by restarting after spinning off the road in the rain - long and largely uninteresting story). And in many cars you can choose "sport" mode or whatever, which allows different shift points, so shouldn't be impossible.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Dec 12, 2015 09:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
