View Poll Results: See my questions in Post 1 of this thread . . .
Copper plugs
66
14.67%
Iridium plugs
130
28.89%
Platinum plugs
254
56.44%
Voters: 450. You may not vote on this poll
5th Gen Spark Plug Replacements
Old Feb 28, 2003 | 08:23 AM
  #41
emax02's Avatar
[QUOTE]Originally posted by MAX2000JP
[B]EMAX
I agreed that with your first part...
No you did not agree with me, you said copper plugs performed better then iridium plugs. That comment is the point of this whole disscussion...
You are buying into the marketing of Iridium plugs. There will be no noticeable difference between new coppers and iridiums. Did you buy Spitfires when they came out?
I'm buying into the best performing plug, period, whether it's worth it to you or others is irrelevent to me.. And very funny about the spitfire plugs
Old Feb 28, 2003 | 08:37 AM
  #42
MAX2000JP's Avatar
I agreed when you said this..."lol, I have read dozens of comments on the org regarding spark plugs and there effects with performace. I have seen ZERO dyno results comparing any of these plugs, all I have seen is hear say"
If you believe spark plugs give you noticeable hp, then I dont know what to tell you. I get a laugh out of people who list spark plugs as a mod on other forums.
Like I said before, Iridiums are a lot of hype. Go talk to a professional engine builder and see what they use on their cars.
Old Feb 28, 2003 | 09:01 AM
  #43
y2kse's Avatar
So then I'm confused by a statement in the Spark Plug Primer I posted in the FAQs, to wit:
"Because of the extremely high melting point of iridium, they can have very sharp tips without risk of melting and they should last a very long time. These would be best for high-rpm NA engines where the sharpest tip is needed for the best spark, but there is little danger of pre-ignition."
Please explain why you disagree with this statement, MAX2000JP.
Old Feb 28, 2003 | 09:48 AM
  #44
simon tx's Avatar
FYI
I followed up on my 30K service by asking the service advisor when/if you change your plugs.
He said the OEM plugs are platinum and if you can get 50K miles out of them it would be a miracle.
He had no opinion on the iridium plugs and of course recommends platinum because that is what Nissan uses.
I find it interesting they would suggest in the OM that the plugs are 100K, but even their service people will tell you half that if you're lucky.
In case you're wondering - Nissan thinks their platinum plugs (the whole set) are worth $88.
Old Feb 28, 2003 | 10:10 PM
  #45
emax02's Avatar
You should try to be a bit clearer when you agree to disagree..
Old Mar 1, 2003 | 05:30 AM
  #46
y2kse's Avatar
Interestingly, MAX2000JP seems to have disappeared from this thread. He did not respond to my question nor has he produced a single shred of evidence to support his position that Copper plugs provide exactly the same performance as Iridium plugs. Under the circumstances, I'm prepared to disregard his comments entirely.
Old Mar 1, 2003 | 10:03 AM
  #47
Colonel's Avatar
Old Fuddy Duddy
If I read the link correctly
Copper is best for FI or Blown applications where detonation is absolutely a non-option. The full copper head allows for better cooling in between ignitions, which is key.
Irridium is better for fast reving NA application because a much better spark can be created. Detonation is slim, but still a possiblity.
I understand the site, but not really sure if there is a definative "this plug" is better than "this plug". Seems likes it application based as well as dollar based.
I think, a perfectly tuned NA motor, you will probably see a smoother running motor with irridium versus copper. Plus it would seem the gap would stay the same longer therefore create better running longer? Now how that relates to getting more HP, I dunno.
Looking forward to additional discussions!
Old Mar 1, 2003 | 10:22 AM
  #48
MAX2000JP's Avatar
My evidence was that I was told this by a my friend's engineer at his Race shop that builds road racing vehicle. Guess what kind of plugs they use on their vehicles and this is running a far more powerful engine with a much advanced ignition system(MSD). I would like to know the credentials of the guy that wrote that article that you linked to. Is it some guy stating his opinion on the matter or is he an engineer? Also, use the search feature here on the .org and you will see people stating the same thing I have.
Again, spark plugs are not going to show a noticeable power increase. For the differnce between the cost of Iridium vs copper, you can almost buy yourself a RVM UDP, which WILL show gains.
Old Mar 1, 2003 | 10:48 AM
  #49
y2kse's Avatar
I don't know the credentials of the individual who wrote the article and I'm unable to access it right now. (The web site appears to be down for the moment.) Perhaps you could refer me to an article on the subject written by your friend's engineer so I could compare the two.
Old Mar 1, 2003 | 11:14 AM
  #50
MAX2000JP's Avatar
When I looked at the site, it didnt point out what his credentials were.
As for my friend's engineer, I don't think he would waste his time writing an article for us. Also, he is very busy right now working on a car they are building. If you want to see some of the cars he has built I can link them to you.....
Old Mar 1, 2003 | 11:55 AM
  #51
y2kse's Avatar
Sure. That would be cool.
Old Mar 1, 2003 | 02:32 PM
  #52
CIRCO's Avatar
This was very entertaining y2kse are you trying to earn the nickname master of all things that spark?
Old Mar 1, 2003 | 03:42 PM
  #53
y2kse's Avatar
Just tryin' to light my fire, CIRCO!
Old Mar 1, 2003 | 04:53 PM
  #54
03BlkSETE's Avatar
Excellent thread. This answers alot of the questions I had. So what plugs did you decide on, y2kse. I'm guessing copper because I think you're a best bang for the buck type of guy. Looks like iridium for me.
Old Mar 1, 2003 | 05:00 PM
  #55
y2kse's Avatar
I'm also leaning toward Iridium. Cost isn't that big an issue. I'm more interested in performance and value.
RVM Racing is selling Denso's for ~ $70.00 a set. That comes out to about $6.00 per plug. I'm not sure how much the NGK Iridiums cost. Anybody else shop Iridium plugs lately?
Old Mar 1, 2003 | 10:20 PM
  #56
irvine78's Avatar
Re: Re: changed at 30K
Good info.
If Org members are going to replace their plugs every 30K, it probably doesn't make sense to buy expensive Platinum plugs. They'd be better off installing Copper or Iridium plugs. Does that make sense?
iridium plugs are more expensive than platinum ones..
since i change my plugs every 4,000-5,000 or every time i come back from a race, i'm running copper plugs.
Old Mar 2, 2003 | 05:51 AM
  #57
y2kse's Avatar
Re: Re: Re: changed at 30K
That makes sense, Hoon. But which plugs would you recommend for those of us who never race . . . copper, iridium or platinum? And how often should we change our plugs?
Old Mar 3, 2003 | 11:26 AM
  #58
y2kse's Avatar
Current Status . . .
Apparently Hoon doesn't have an answer for those of us who don't race our Maximas.
So here's where we stand. Approximately half of those who have replaced their spark plugs used platinum plugs and the other half used either copper or iridium plugs. Unfortunately, there seems to be little in favor of using platinum plugs. Copper plugs are cheaper than platinum and provide the best conductivity. Iridium plugs are about the same price as platinum and provide the sharpest electrode due to their ability to withstand heat. So I have to assume that most of those who chose platinum plugs didn't do much research before arriving at a purchase decision.
Correct me if I'm wrong, platinum plug users.
Old Mar 4, 2003 | 08:37 AM
  #59
y2kse's Avatar
Interesting . . .
Sixteen people replaced their spark plugs with platinum plugs. But not a single one of them is willing or able to defend their purchase decision.
I suspect those who chose platinum would do well do avoid Pied Pipers.
Old Oct 31, 2003 | 02:45 AM
  #60
SkylineGTR's Avatar
Coppers are best when boosting or spraying.
Iridium vs Platinum, I'd say is rather negligible. Even if one gave 1hp gain over the other, theres still a lot of other factors that determine what ET you run. Iridiums are more pricey, if ET matters that much, take out the passenger seat, its free and you would gain more from that than paying premium prices for clever marketing.
TK
PS I'm not bashing Iridiums, frankly I buy into the marketing of spark plugs, and the whole melting point of the tips and such. Yeah in a high revving NA motor maybe the Iridiums are better, but in terms of daily driving, the difference isn't worth noting.
Old Oct 31, 2003 | 04:25 PM
  #61
ppetruccelli's Avatar
The pump screen can be cleaned through a back seat passage. Lift your rear seat and you'll see the access port.
Originally Posted by foodmanry
Technically 5th gens don't have a fuel filter, it's more of a strainer. Also it's located in the fuel tank so the dealer would have had to drop the fuel tank to change it. You might want to check and make sure they didn't hose you on the job (charge you for the house without doing the work) by asking them how they changed the "filter".
Old Nov 1, 2003 | 01:59 AM
  #62
beemreatr's Avatar
I switched to iridium at 27k. I think they were a waist of money, no difference for me.
Old Nov 1, 2003 | 08:24 AM
  #63
maximum007's Avatar
Does everyone agree the NGK is the best brand?
Old Nov 1, 2003 | 08:42 AM
  #64
maximadave's Avatar
detailerdaveb@gmail.com
NGK Platniums at 46K. Big difference in throttle response. I'll take pics of the old ones. They show detonation on the plugs big time.
Old Nov 1, 2003 | 09:00 AM
  #65
Raf2kMax's Avatar
i bought densos from rvm a couple months back and installed it in my max. car had better response and what not i thought. cost was a lil less than 70 i think..like 62 or something..not sure. but i picked it up from their warehouse.
Old Nov 16, 2003 | 10:30 PM
  #66
Spartan5's Avatar
Originally Posted by 00SESoonToBe
I am getting the Bosch Platinum plugs and wires next month @44K miles. How well do the Bosch's hold up?
DO NOT USE THE BOSCH PLATINUM +4's....REPEAT...DO NOT USE THESE.
The very small platinum tips builds deposits quite quickly and get rendered ineffective. When my performance started going down, I asked my dealer why my car ran terribly and he asked me if I had Bosch's even before I told him they were in there. Turned out my MAF sensor was the problem, but I yanked the Bosch's, took a look, and with about 10K miles on them, they looked terrible. The dealer wanter $11 a plug for the stock NGK platinums, so I put in the NGK V-coppers for $2 a plug and am getting stellar performance. Good luck.
Old Nov 17, 2003 | 06:23 AM
  #67
georged98's Avatar
Originally Posted by emax02
I was under the impression that iridium plugs would out last platinum plugs. At $15 a pop I hope so
I personaly put Denso iriduim plugs in my 2002 max at around 20K miles. Reason for doing so is because my oem ones got fouled after several MAFS failures. I chose iriduim plugs becuase they are the industrys best.
How hard is it to replace the spark plugs in a 2002 Max??? I have a 2002 GLE.
Thanks.
Old Nov 17, 2003 | 11:03 AM
  #68
Y2KMaxGXE-R's Avatar
this is all bs, the condition of your car is the best indicator when you need to have your spark plugs changed. If your car is hard to start in the cold weather, uneven idle, poor gas mileage, then you change them. If it ain't broke don't fix it.
Old Nov 17, 2003 | 01:21 PM
  #69
pruizgarcia's Avatar
Changing front plugs on the 02-03 is a breeze. The rear ones are another story; the back (intake I think) will have to be removed to get to the plugs. My Max has 29K so don't need to change them now. Anyone has pics on replacing the rear plugs? Had Denso Iridiuim's on my 99 Max and throttle response was a lot better IMHO.
Pedro
Old May 25, 2004 | 05:21 AM
  #70
2002 Maxima SE's Avatar
emax,
Did you change them yourself?
Old May 25, 2004 | 05:45 AM
  #71
Pedro
Check out this write up. I'm hoping emax can add more knowledge and pics to the write up.
2002 Sparkplug Change
Old May 28, 2004 | 10:05 AM
  #72
ttt
1234567890
Old May 28, 2004 | 06:19 PM
  #73
slvr2KSE5's Avatar
1991 3000GT VR4 nicely modded.
13.1 PSi.....iridiums=massive spark blowout with .032 gap.
15.1 psi.....NGK coppers=no blowout noticed of any kind with .032 gap.
both plugs brand new at install. pulled iridiums out after 1k miles. got sick of blowout at such pathetic boost.
seen video and pictures of copper/plat/iridium plugs during spark.....copper had the largest and most precise spark. iridiums had a thin little orange line. plats were blue and a bit fatter. copper was fat and white.
i will never touch iridiums again after personal experience and seeing this.
Old Jun 2, 2004 | 07:18 PM
  #74
Larrio's Avatar
The Definitive AE Master
i just replaced mine this weekend with oem nissan platinum plugs at $8 a piece.
I bought the car used with only 27k on it and when I pulled the plugs they were frosted, most likely detonating from the original owner putting in regular gasoline.
Old Jun 6, 2004 | 05:39 AM
  #75
Ammi's Avatar
350 Detroit Muscle
Iridiums are overkill for NA cars. Copper plugs will work just fine for most of us.
Old Jun 6, 2004 | 06:33 AM
  #76
Wurf's Avatar
Plugs
I've read a number of SC articles with SBF motors where they put Iridiums in the motor and picked up significant HP. Those motors used aftermarket ignitions systems however - specifically MSD boxes. I'm sure that makes a difference. There were over 10lbs boost as I recall.
For a naturally aspirated car...sorry a "NA" car ( forgot to use acronyms again ) with a stock ignition system, a copper or platinum plug would work just fine. The Iridiums are a WOM IMO.
I'm going with the NGK copper plugs when I replace mine.
Part Number: LFR5A-11
http://www.ngksparkplugs.com/images/tip/ngk41A.jpg
Old Jun 6, 2004 | 09:00 AM
  #77
ihavea5spd's Avatar
i switched to coppers. no difference.
Old Dec 6, 2004 | 08:25 AM
  #78
MrPoisse's Avatar
I recently bought spark plugs from Dave Burnett...
he told be the OEM are well enough if the car isnt modified.
and btw, here's a cool link for you to change your splugs on your own.
http://www.nissanx.net/tanman/
Old Dec 6, 2004 | 08:26 AM
  #79
nestor's Avatar
i had that ignition coil problem happen to me at around 70k and i had the spark plugs replaced at the dealer with the oem platinums... at least that's what they told be, but i don't believe anybody. they said they did the engine flush (bs, i know) but then i needed throttle body work a month later... come on! anyway, the engine (note just the engine) performs fine. i have no qualms about it, in fact, i love the vq!! wonder if i should have switched to coppers or something. damn, didn't think of it at the time. i was feeling sorry for myself and my missy (my max) because she was driving like ship (sic).
Old Dec 13, 2004 | 01:15 PM
  #80
SterlingMist00's Avatar
anyone who installed the DENSO Iridiums......
...........on a 2k Max (plug number IK20). I need to know what the plug size is- i.e 14mm flat seat or 14mm tapered seat so that I can figure out the torque settings off of DENSO's website...
thanks
Angelo
