Received my stillen rotors and brake pads
Now I Just need to find HOW-TO
can someone tell me where to look?
thanks
btw, my friend wanted to ask .org if we have to spray anything on the brake pads, so they won't make any noise after installed?
thanks
Re: Received my stillen rotors and brake pads
thanks
thanks
thanks
thanks
Re: Re: Received my stillen rotors and brake pads
Originally posted by karguy
Nice write up and pictures on www.motorvate.ca for fronts. Once you do the fronts you'll have no problem with rears. Need tool to rotate rear caliper while pushing caliper back in. If you feel lucky you can try to do it with needle nose pliers. Tool is called Disk Brake Piston Remover. Many parts stores will loan it to you. I have never sprayed pads for squealing but I use synthetic high temp brake grease on clips and CRC Anti Squeal Compound on back of pads and shims. Hope this helps!
ya just for the front.
so do I still need to spray that stuff?
1 more question my friend wants to know, how much are we suppose to torque wrench?
thanks
thanks
pin bolts F & R 16 - 23 ft lbs (little bolts)
Torque member fixing bolts F 53 - 72 (big bolts)
Torque member fixing bolts R 28 - 38 (big bolts)
You'll need a C clamp to push the front calipers pistons back in.
While you're at the part store get the Haynes Manual, only $15. I use CRC aerosol Brake Cleaner to clean up the caliper, get 3 cans. Again I don't spray anything on the pads, I just use Synthetic grease and CRC Anti Squeal Compound. Have fun.
lug nuts 80 ft lbs
lug nuts 80 ft lbs
If u are a tech I got a question about a new Snap-on tool im just tryin to get a bit more info on.
Originally posted by HitManSE
Hey I was just wondering, are u a tech or just very informed? Im not trying to insult u in anyway. Just the way u answered those questions is the way a professional mechanic would.
I posted a HOW-TO on Rotors and Pads in this forum. Did you look? The 8th post down on page six of the HOW-TO thread.
http://forums.maxima.org/showthread....5&pagenumber=6
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
