50% power gain with a supercharger?
I posted this before hoping some one knew a little more about the vortech superchargers then me. all i got was a bunch of junk and some kid whining aabout the power lost by his transmission. so i am going to try again
I have been told a few times that if you run the right superchager set up you can get near 50% more horsepower. then i read all this people talking about how much power they got on their maxima's and it is no where near that. i even saw a guy who was running smaller pulleys and wasn't near 50%. why is this? is it because they are not running a very good set up or do vortechs suck ( i did here that vortechs can make you run lean and that could be fixed with bigger injectors.) could it just be to much parasitic drag ( and if so will under drive pulleys fix that)or is the unit just to small.and finally if the 50% gain is true then can the maxima's manual transmission handle that extra power? ( i know that many other nissan's such as the 240sx can handle that kind of power)
Re: 50% power gain with a supercharger?
Who told you that crap? It could be false advertising. Suppose the 2k2 Maxima has 255hp. 50% more hp means adding 122hp by simply adding a supercharger? Get real, dude!
~limsandy
~limsandy
Re: Re: 50% power gain with a supercharger?
~limsandy
~limsandy
Re: Re: Re: 50% power gain with a supercharger?
Originally posted by optimus1
stock = 190 -200 hp; some members are getting 300 hp = = 50% increase, do the math ...
Yeah 50% gain is pretty common with a supercharger and an ECU remap + fuel injectors..
Votech makes great kits.
If people aren't getting 50% gain, they threw $3k+ down the toilet because they have no clue how to properly tune it which means they probably have no clue how to maintain it, either!!
sheesh..
sheesh..
Re: Re: Re: Re: 50% power gain with a supercharger?
Originally posted by Newman
that is with muffler, b pipe, y pipe, intake, UDP ...etc.. AND supercharger
Originally posted by johnnydddddddd
why?
why?
Re: Re: Re: Re: Re: 50% power gain with a supercharger?
Originally posted by Regime
Don't think you would want to use an UDP when supercharged...just my 2 cents
Re: Re: Re: Re: Re: Re: 50% power gain with a supercharger?
Originally posted by Y2KSESteve
You use a different pulley with the supercharger, thats where you get your boost.
Yes, you can boost a 2k1 automagic, or even turbo, just ask BigDogJonx. If you boost you almost need a full exhaust, no use trying it without certain upgrades, motor mounts, VB mod for autos, that sort of thing. A 2k1 will dyno at about 165-175 so getting an extra 80-90 at the wheels would be 50%
Originally posted by sighere
Is a SC for 2k1 with automagic available?
