to ALL with AFTER MARKET ROTORS!!!
Old Mar 7, 2003 | 10:21 AM
Igor911's Avatar
What rotors are you using and what brake pads?
Please state if you are happy with the setup and/or what problems you are experiencing.
Old Mar 7, 2003 | 10:46 AM
raiderttu's Avatar
I got the 4 slotted rotors on the group deal from Raceconcepts.net. I'm using axxis semi metallic pads from autozone.
I had an initial problem with the rotors and had to have them turned out of the box but now they are great. I really need them in Austin traffic.
Old Mar 7, 2003 | 10:53 AM
Maximam's Avatar
Stillen rotors and pads, like them!
Old Mar 7, 2003 | 10:57 AM
HitManSE's Avatar
Stock.
Old Mar 7, 2003 | 11:08 AM
Igor911's Avatar
I have the axxis pads and they are causing trouble for me
Old Mar 7, 2003 | 11:32 AM
NuJerseyDrive's Avatar
Stillen cross drilled rotors/Porterfield R4S pads. Installed approx 10,000 miles ago. I'm still very happy with them.
Old Mar 7, 2003 | 11:50 AM
Igor911's Avatar
Wow...very expensive pads!
Old Mar 7, 2003 | 12:13 PM
blackY2Kmax's Avatar
What trouble? I have stillen cross drilled rotors and axxis metal master pads - all from phoung. I haven't had problems per se with the pads, but they are a touch noisy.
Old Mar 7, 2003 | 12:15 PM
jnovember's Avatar
Stillen cross drilled rotors and axxis metal master pads on the fronts only (still original stock on the rears). 30k miles. No problems.
Old Mar 7, 2003 | 12:16 PM
Igor911's Avatar
My exact setup... I have has 2 sets of rotors in 6 months w/ same problem.
WTF
Old Mar 7, 2003 | 12:17 PM
Igor911's Avatar
http://mywebpages.comcast.net/igor911/car/rotor1.jpg
http://mywebpages.comcast.net/igor911/car/rotor2.jpg
Old Mar 7, 2003 | 12:42 PM
foodmanry's Avatar
Da Roller Coaster!
Custom powerslot x-drilled, and slotted rotors. Axxis Metal Master pads. No problems.
Old Mar 7, 2003 | 01:10 PM
HitManSE's Avatar
Hmmm, are u still on the same set of axxis pads since this is ur second set of rotors? It might just be screwed up pads. If that doesnt fix the problem id just go 4 the powerslot x-drilled rotors. I want to try the stillen but now that i see urz im not too sure anymore. They look nice, but they need to work perfect obviously. Looks like the pads are just chewing threw the rotors.
Old Mar 7, 2003 | 01:12 PM
Igor911's Avatar
I also changed the pads on the 2nd set. I started fresh and now look what happened...
Old Mar 7, 2003 | 01:46 PM
kpark's Avatar
Powerslot rotors and Axxis Metal Master Pads. Hasn't even been 1000k since I put them on. But so far they're great. Waaayyy better than the stock rotors.
Old Mar 7, 2003 | 02:06 PM
ebmaxse's Avatar
Rotors:Raceconcepts fronts-dimpled/slotted, rears - slotted.
Brake Pads: Raybestos Quiet Stop Ceramic.
No problems, great combination.
Old Mar 7, 2003 | 07:01 PM
Max_5gen's Avatar
Stock rotors(second set, replaced together with stock pads). R4S- front, Vagner(noisy)-rear. Love R4S, already on the second set, no problems with rotors and they've already gone twice as much as the first set.
Old Mar 8, 2003 | 12:32 AM
SterlingMist00's Avatar
Stillen x-drilled rotors, Axxis MetalMaster pads with SS lines and Motul 600 fluid. About 6 thousand miles on them.....no problems.
Apr 16, 2020 05:15 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
Maxie40
Sep 14, 2015 11:28 AM
