Clear corner moisture problem
Old Mar 9, 2003 | 01:03 PM
wolf0's Avatar
I never put silicone on my clear corners when i installed them. What is an easy way to get the moisture off the lense so that I can seal them properly like i should have done originally. Anyone?
Old Mar 9, 2003 | 01:30 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
Re: Clear corner moisture problem
never had this problem... did silicone on mine...
but ive heard about taking a hair dryer to them ... even heard putin em in the oven on low for a bit...
basically HEAT to dry it out!
Old Mar 9, 2003 | 02:00 PM
griffy2k2max's Avatar
take the bulbs out of each lens, pour a little alcohol into the hole swoosh it around and pour out the excess alcohol, then heat with a hair dryer or hold it over a halogen lamp if you have one, maybe the bedroom or living room,move the assmbly back and forth don't get too close the light element or you will either melt the lens or burn yourself! after that put the bulbs back in, apply a bead of silicon around the back of the lens where the backing and the lens are connected. this took about 30 min to evaporate the water. the silicon may take about 4 hours to dry
Old Mar 9, 2003 | 02:08 PM
wolf0's Avatar
Thanks for your help
Old Mar 9, 2003 | 02:14 PM
No Problem
Mar 12, 2020 12:06 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
Steven Orozco
Sep 12, 2015 10:41 PM
slowlifer
Sep 8, 2015 05:53 AM
