Check Engine Light On!
Old Mar 9, 2003 | 02:24 PM
Jacawarner's Avatar
Hi All,
My 2000 SE's Check Engine light came on. No driveability problems, but made an appt with the NIssan dealer here in North NJ to get it fixed (under warranty-car only has 28k on it). I've seen too many posts about people getting the shaft at The Shift_. I want to avoid any problems when I take the car into get repaired this Tuesday, what can I look out for"
Jan
Old Mar 9, 2003 | 05:53 PM
Wasim521's Avatar
Take the car to an Autozone, they scan the check engine lights for free with one of those OBD II scanners, it'll tell you why the light is on. That way, if Nissan tries to pull any BS with you about the light, you'll know.
Old Mar 9, 2003 | 10:14 PM
zman187's Avatar
chances are its nothing much....
Old Mar 9, 2003 | 10:16 PM
02'maxed-out's Avatar
I have the battery sit for a night disconnected... Negative terminal, I see what happenss... should take care of it...
Old Mar 10, 2003 | 10:28 PM
jjsokul's Avatar
ok
it did work for me!!!
I disconected the battery for 10 minutes and put it back on, and problem solved.
Old Mar 10, 2003 | 11:52 PM
You welcome...
Old Mar 11, 2003 | 04:56 AM
MoCoMax's Avatar
Re: Check Engine Light On!
Originally posted by Jacawarner
Hi All,
Jan
Which dealer are you going to? I wound up at Hilltop in E Hanover, and the service manager there is a snake. He copped a huge attitude with me when I argued that my 2K with 32k miles was covered for brakes and coil under the TSB's. He went so far as to make me get him the TSB # on the coil before he'd warranty it.
If you're in the Parsippany area anytime before you go to the dealer, PM me. I've got a code-reader we can hook up, so you'll at least be armed with some info on the problem before you get to the dealer.
John
Old Mar 11, 2003 | 03:39 PM
Jacawarner's Avatar
Re: Re: Check Engine Light On!
John
Old Mar 11, 2003 | 03:48 PM
Jacawarner's Avatar
Thanks for the offer
Thanks for the offer John,
I live and work in West Caldwell off of Passaic Avenue. I actually dropped the car off and picked it up today at Nissan 46 in Wayne. There wasn't anything really wrong, no actual replacement of parts and they reprogrammed it. They said I'm about due for my 30k service and tried to talk me into spending $489 for the service which I of course turned down.
I actually want to buy a code reader, where did you get it? It's a good tool to have.
Jan
Old Mar 11, 2003 | 04:00 PM
MoCoMax's Avatar
Re: Thanks for the offer
Jan
I ordered the Equus 3100 reader on-line from a site called toolsource.com. I think I paid about $140 with the cables and a case. If you have a Palm device, I found a site that can sell you a cable for it that is supposed to work, too, though I don't think the Palm reader will re-set the codes like the 3100 will. If I find it, I'll send you the info.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
