Why is rear suspension so bad?
Old Mar 12, 2003 | 11:07 PM
lmac's Avatar
It seems like the rear end bottoms everytime I go over a speed bump. I have to almost come to a complete stop and slowly take speed bumps. I could go over them in wife's '97 Civic at close to 25MPH and it goes over fine. I hate it when I have to slow down so much and some idiot gets right on my tail. It's embarrassing with such a new car. Will the dealer do anything about it or will they simply tell me its normal? I'm sure this has probably been addressed before, but I can't do a search.
Old Mar 12, 2003 | 11:26 PM
02'maxed-out's Avatar
i don't know why neither... ever since i put that rsb in...
Old Mar 13, 2003 | 02:46 AM
Virus's Avatar
Where did you put the bushings on the axle? I had mine about a inch from the bends and it bottomed out frequently due to the arm coming down and hitting the bushing. Once I moved it 4.5 to 5" out it was fine.
Old Mar 13, 2003 | 07:17 AM
asu174's Avatar
Clay Aiken has fancy genitals
Threads like this are the primary reason why the RSB is the only bolt on that I do not have.......
Old Mar 13, 2003 | 07:41 AM
daveful's Avatar
My 03 SE did the same thing. When the car was loaded it was down right scary when it bottomed out at speed. The roads down here in New Orleans have lots of bumps and undulations so the suspension caused me alot of concern. In addition the front end banged on bumps that my other cars, including my stiffly suspended RX-7, just rode over. Of course the dealer(s) all thought it was normal. I got rid of the car after 3 months due in part the poor suspension.
Old Mar 13, 2003 | 10:52 AM
HKMax's Avatar
I suspect it is because the rear suspension is beam axle. I really hate Nissan for doing this. All other "normal" sedans, even SUVs, come with independent rear suspension. I believe Maxima used to come with one and they switched for some reason. Now I know why Max is not in 10 best list in C&D.
Old Mar 13, 2003 | 10:54 AM
slickrick's Avatar
Re: Why is rear suspension so bad?
dealer wont do ****. but suspension mods should help.
Old Mar 13, 2003 | 10:57 AM
Maximam's Avatar
Your answer is the springs and shocks are to soft. I have the same problem.
Old Mar 13, 2003 | 10:58 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
BECAUSE YOU DON'T HAVE THESE
http://forums.maxima.org/showthread.php?threadid=196636
Old Mar 13, 2003 | 12:00 PM
kpark's Avatar
Re: BECAUSE YOU DON'T HAVE THESE
But the Max only has struts in the front and shocks in the rear.
Old Mar 13, 2003 | 12:07 PM
IceY2K1's Avatar
Re: Re: BECAUSE YOU DON'T HAVE THESE
Front=shocks
Rear=struts
Unless I'm going
Old Mar 13, 2003 | 12:14 PM
young1976's Avatar
Re: Re: Re: BECAUSE YOU DON'T HAVE THESE
Originally posted by IceY2K1
Front=shocks
Rear=struts
Unless I'm going
UHM, YEA, FRONT STRUT, REAR SHOCK( ON THE BOTTOM ) BUT MOUNTED LIKE A STRUT (ON TOP)
Old Mar 13, 2003 | 01:12 PM
IceY2K1's Avatar
Re: Re: Re: Re: BECAUSE YOU DON'T HAVE THESE
Then that's why these will work.
4th gen struts...er shocks...whatever...are the same as 5th gens.
Whatever you call them.
Old Mar 13, 2003 | 01:35 PM
Young04's Avatar
does it get worse when you have people in back seat or luggage? i took my car in for the same reason, and theer is a TSB out there for us GLE guys. i'm having my springs replaced on wed. good luck!
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
FlaMark
25
Aug 28, 2015 10:15 AM
george__
Aug 18, 2015 07:06 PM
laparka66
Aug 6, 2015 09:36 AM
