New Rims
Old Mar 12, 2003 | 11:42 PM
andrew3616's Avatar
New Rims
Im in the market right now for some new rims. I have 16" stock rims but i dont want to lose the performance if i get bigger rims, i acutally want to gain some. So what are the best rims for perfomance and looks. I dont want anything smaller then 16. But i would like to go bigger than 16 if possible, and keep the same performance. Thanks
Old Mar 12, 2003 | 11:44 PM
02'maxed-out's Avatar
get yourself some 18's... no use spending any money if you are going to keep the same stock size...
Old Mar 12, 2003 | 11:46 PM
GundamWZero's Avatar
Go 17"s with low profile tires.....won't lose tire size by much....
Old Mar 12, 2003 | 11:47 PM
andrew3616's Avatar
im pretty set on the evo5s but how much does performance suffer with a 18 evo5. I would think alot
Old Mar 12, 2003 | 11:51 PM
Evos on 18"s with low profile tires will look like and be around 17"s
Old Mar 12, 2003 | 11:52 PM
18's on low pros will definitly do the job... of course you are going to feel the road more, but come on sacrifice a little comfort and cruise in style...
skyjay617's Avatar
Re: New Rims
definately 18" OZ superleggera. sweet looking and light weight.
Old Mar 13, 2003 | 12:00 AM
Good choice...
Old Mar 13, 2003 | 08:02 AM
naerok's Avatar
Re: New Rims
I am also in the market for some new/used rims. I saw some on ebay. The evo's. I dont know anything about tires/rims sized and what it means to offset. Could explain this to me.
the rims size i was loooking at was 19x8.5 and tires are 225/35zr/19. These wheels have a +40 offset and 5x120 P.C.D. (I have no idea what this means) Can someone explain this to me and will it fit my 01 max?
Newbie...
Old Mar 13, 2003 | 12:45 PM
naerok's Avatar
Re: Re: New Rims
Newbie...
Can anybody comment?
Old Mar 13, 2003 | 12:57 PM
asu174's Avatar
Clay Aiken has fancy genitals
225 series on an 8.5" wide wheel is a very, very, very bad idea.
Also, we are 5x114.3, not 5x120. They will not fit.
Old Mar 13, 2003 | 01:17 PM
PoLo's Avatar
2-Wheelin it...
245/35-19 is closest with speedometer specs and wide enough for an 8.5" rim.
Old Mar 13, 2003 | 01:36 PM
naerok's Avatar
Thanks for the info. I was going to bid since it was at a good price. Hopefully in the future, there will be another set of evo's on ebay.
Old Mar 13, 2003 | 01:46 PM
YAMATOSOUL's Avatar
Re: Re: New Rims
Newbie...
I worked in the automotive aftermarket for many years, and I can help you out here. Yes, those wheels should fit. The proper offset for your car is between 35mm to 40mm and the bolt pattern should be 5x114/120. For an explanation of offsets and other terminologies, go to www.tirerack.com. As for P.C.D., I'm pretty sure that they're referring to the finish of the wheel. I think it's an acroynym for "polished, clear coat, and ???". However, you can do better with the size of both the tires and wheels. Aesthetically, larger wheels with thin rubber band tire do look sharp, but performance wise, you lose out. In the real world, you need some actual height and thickness on the tires to absorb the imperfections of the road. They need to give enough for little rocks and pot holes so that you can achieve a balance of both handling and ride comfort. If I were you, I wouldn't go any larger than 18" for the wheels. You should, however, go wider (8" to 8.5"). As far as the tires are concerned, try 235's or 245's in 40 series. I'm sure you'd like the handling much better with those. And later if you decide to drop the car, try Eibach springs. They'll drop your front about 1.3" and the rear about 1" (actually it'll continue to settle a bit more in time), and they will fill the wheel well real nicely with your wheel/tire set up. Good luck.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
