2KSE Offset- Need Help
Old Mar 13, 2003 | 07:26 AM
Rgamfn1's Avatar
I was told the offset for our 17" wheels is +45mm.
I this true? Does that mean we can't put 20mm offset rims on there? Even if the lug and bolt pattern is the same?
Old Mar 13, 2003 | 07:40 AM
UMD_MaxSE's Avatar
Got Bent?
stock is 45 offset... 20 will not work. You need a wheel with offset between 35 and 45.
Old Mar 13, 2003 | 07:41 AM
PCGuRu2K's Avatar
Re: 2KSE Offset- Need Help
The lower the offset the more it will sit out of the fender well... I have 38+mm on mines that is is perfect imo... I don't think anything lower then 38+ is recommended. Out bolts pattern is 5X114.3.
Old Mar 13, 2003 | 08:15 AM
Hobert's Avatar
Re: Re: 2KSE Offset- Need Help
Aren't emax02's SSR Integrals 18x8's with a 35mm offset? They look good.
Old Mar 13, 2003 | 07:33 PM
02VQ35's Avatar
I was told that the offset on SE wheels is 40mm, not 45, 45 on the GLE 02 and 03 wheels. Maybe i'm wrong, but check your owners manual. Nissan tells you everything about the wheels on your car. Chris
0to60inhocuspocus
Jul 8, 2015 05:46 PM
0to60inhocuspocus
Wheels/Tires
Oct 1, 2013 06:45 PM
lux97Max
Wheels/Tires
May 9, 2011 10:13 AM
RAUF
Aug 1, 2003 06:30 AM
Foglght
Mar 29, 2001 12:26 AM
