Distributor Signal Interrupt
When I pull my codes off my 2k Maxima, I get a Distributor Signal Interrupt Code. I replaced a failed coil that was giving me a misfire in cyclinder #1. The symptoms of my present problem include intermittent rough idle, loss of power on acceleration and bad gas mileage. Is there a distributor module that could be causing the trouble? What would cause this problem?
Re: Distributor Signal Interrupt
Sounds like another bad coil to me. They apparently won't always throw a code when they go bad.
since we dont have distributors, hard to say :/ if you're sure its not the other coils (and it likely is), there is another TSB out for wire breaks in the harness near the right strut tower.
Re: Re: Distributor Signal Interrupt
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
