Stock Resonator
Re: Stock Resonator
Originally posted by NikaL
How restrictive is stock resonator? I knew crushed section is really bad on stock B-pipe. Will I get any gains if a have a muffler shop change section from resonator to muffler?
Re: Re: Stock Resonator
Originally posted by sloppymax
you would see slight gains, im thinking 3-5hp for replacing the two crushes in the piping.
Thanks Sloppymax.
I'm waiting for Catttman's headers. When it comes out, I'll be getting headers and Y-pipe. Did you keep you stock resonator? I don't want to remove it, because of noise. $40 is a good deal, even for 1-2 hp.
you would see slight gains, im thinking 3-5hp for replacing the two crushes in the piping. my local meineke replaced mine with 2.25 piping for 40 bucks, so for that price i didnt mind. i checked your sig and i would get a y pipe before i got the b pipe. you will see better gains from freeing that up espically if you are fed spec 2000. then doing the b pipe after might rise the gains of the b pipe a littler more.
Re: Re: Re: Stock Resonator
Thanks Sloppymax.
Thanks Sloppymax.
Re: Re: Re: Re: Stock Resonator
Originally posted by y2kse
I'd strongly recommend AGAINST removing the resonator from your B-pipe, NikaL, particularly given the fact that you're planning to install headers and a Y-pipe. I'd suggest you replace your OEM resonator with a Magnaflow resonator instead.
Re: Re: Re: Re: Re: Stock Resonator
I don't want to take off the resonator either. I want my car to be as quiet as possible, while still gaining hp over stock. Will Magnaflow make my car louder?
Thanks Sloppymax.
Thanks Sloppymax.
04-16-2020 05:15 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
