Any way to engage the door locks/alarm silently w/out the horn?
Old Mar 20, 2003 | 07:03 AM
UCF_94lude's Avatar
On the factory alarm and keyless entry unit, how the hell can I arm the thing without the horn sounding??
Old Mar 20, 2003 | 07:05 AM
bert's Avatar
RTBOYKF
Read The Back Of Your Key FOB!
Old Mar 20, 2003 | 07:54 AM
Onemax's Avatar
Originally posted by bert
RTBOYKF
I actually did read the back and thought it would tell you.
But to help a fellow max member out. You have to hold the lock and unlock buttons on you key fob at the same time. It will then cycle through to have just the lights blink or not at all(I think) when you lock the car.
Old Mar 20, 2003 | 08:00 AM
[maxi-overdose]'s Avatar
when your security horn is not working.
happened to me, it was loose and wasnt grounded properly.
Old Mar 20, 2003 | 08:03 AM
bobcat's Avatar
the 2k2/3 remotes are totally different from the 2k/1 ones. Nissan used generic ones for the 2k2/3 ones so they don't have any instructions. I assume the same button combination works tho.
Old Mar 20, 2003 | 08:12 AM
massvmax2003's Avatar
Hold both buttons down for 2 seconds (or until the lights flash)..
This will do the trick..
Later,
Nick
Old Mar 20, 2003 | 09:13 AM
UCF_94lude's Avatar
Later,
Nick
Thanks, I figured it out.. I never knew you could lower the windows with the key FOB though. sweet!
Old Mar 20, 2003 | 09:26 AM
NizanDrivn's Avatar
UCF_94lude
Dude...run a search for FOB open windows...
Ohhh yeahhhh...
Old Mar 20, 2003 | 09:33 AM
UCF_94lude's Avatar
Originally posted by NizanDrivn
UCF_94lude
Ohhh yeahhhh...
exactly.. nows the time to be lazy and get away with asking rookie questions and get away with it with a good excuse.
Old Mar 20, 2003 | 09:49 AM
Axel's Avatar
That doesn't work on the 2000. (and probably the 2001 as well).
Although I've never in my life had the urge to open up every window at once
Old Mar 20, 2003 | 09:53 AM
Just the two front windows lower i believe..
Later,
Nick
Old Mar 20, 2003 | 09:54 AM
UCF_94lude's Avatar
yeah but down here in florida with summer, theres nothing worse then getting into a car with all black interior thats sat in the sun for a couple hours. Lowering the windows beforehand definetely helps.
Old Mar 20, 2003 | 10:27 AM
max...to the ma's Avatar
it would be better if u could turn on the air conditioning they should put that on the engine starter remote i got
Hobert's Avatar
definitely...
Old Mar 20, 2003 | 10:31 AM
MaximaMan77's Avatar
Well I would think not in Canada. Down here in GA thats another story
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
