Stage II HID upgrade
Old Mar 22, 2003 | 02:14 PM
MAXRAY's Avatar
Where the best place to get Stage II HID upgrade bulbs?
What is the bulb "size"?
Is it truly a plug-n-play?
Any experiences would be appreciated...
Old Mar 22, 2003 | 05:41 PM
HitManSE's Avatar
Try this: http://www.hids4less.com/www/index.asp
Old Mar 22, 2003 | 07:19 PM
Bulldawg's Avatar
What are these things and what do they do? is it just like a HID bulb replacement.
Old Mar 22, 2003 | 07:37 PM
HitManSE's Avatar
I dont have Hids. But im not too sure about what these things are. I know that its an upgrage from ur current 4100K's on the 2K2, to 6000K which IMO looks sweet, like what ud seen on a bimmer. If its just a bulb replacement then thats sweet, but im not too sure if u have to upgrade the ballasts. The stock 1z and these both run at 35watts so I dont think u have to change the ballast, but U might want to call and confirm this to be 100% sure.
Old Mar 22, 2003 | 08:08 PM
HitManSE's Avatar
Actually if u got to products, then retrofit kits, just punch in the the cars info and ull find a stage 2 upgrade which is just the bulbs.
Old Mar 22, 2003 | 08:36 PM
ch13f's Avatar
I think by going to a higher "K" bulb, you will actually loose light output, the extra blue tint will look pretty good though.
Old Mar 23, 2003 | 11:18 AM
2M0A0X2's Avatar
actually, i was looking into a new ///M for myself, and the other m3 owners said that they came with 4300k, not 6000k.
Old Mar 23, 2003 | 04:15 PM
NT2SHBBY
Actually guys...FYI
I had an HID retro kit in my old 02 Altima 2.5SL and I originally bought the kit from www.misterjung.com with 6000k bulbs.
Over the course of 6 months, one of the bulbs would take longer to warm up to it's whiteish blueish color so I sent em back to Misterjung for replacement under warranty. Well anyway I also wanted something bluer, didn't really care if there was some light loss due to the drop in lumens, so I went with the 7500k which turned out a bit too blue but just so you guys know, all I did was purchase the bulbs, ballasts were original and they worked fine, albeit a bit too blue and actually to answer the light loss, there was none actually due to the fact that they were bluer, the road actually lit up more!!
I find with my 03, the lights are bright but I dont like that "white" projection. I want something like the 3.2TL, 7000k....I'm going to purchase new D2R bulbs from Misterjung.com and I'll post pix
Old Mar 23, 2003 | 04:21 PM
HitManSE's Avatar
Originally posted by NT2SHBBY
Actually guys...FYI
That would help alot, thank u in advance.
Old Mar 23, 2003 | 08:03 PM
MAXRAY's Avatar
does anybody know if we need D2S or D2R bulbs w/ OEM HID?
Old Mar 23, 2003 | 08:17 PM
MacAlert's Avatar
If in doubt, look on the headlight housing. They have the bulb type on it. Its D2R.
Old Mar 23, 2003 | 08:52 PM
MAXRAY's Avatar
thanks. however, i'm outta town for a couple more weeks w/o my max that's the reason i couldn't take a look.
secondly, hids4less lists D2S as the replacement so i'm still confused...
Old Mar 24, 2003 | 07:55 AM
NT2SHBBY
hids4less looks like a totally b.s. site...I'd go with www.misterjung.com for D2R bulb replacements. He is cheapest around, warranties everything and has all bulb colors to choose
Old Mar 24, 2003 | 08:55 AM
PCGuRu2K's Avatar
Anyone know what the max amp fuse we should use for the hids? 30amp?
Old Mar 24, 2003 | 10:22 AM
NT2SHBBY
I know the 02 Altima with HID upgrade needed a 20 amp fuse...so I'm guessing its the same
Old Mar 24, 2003 | 10:22 PM
MAXRAY's Avatar
misterjung.com does seem to have better prices, but hids4less.com offers 5 year warranties on the bulbs. i'm not sure what type of bulbs are offered at misterjung's, but hids4less sells philips german made bulbs (not taiwan or whatever)
Old Mar 24, 2003 | 10:27 PM
HitManSE's Avatar
Thats the 1 thing I like about it. Germen made, besides a stage II upgrade to a 2k2-3 will look sick. I just want a purplish hue to the HID, and might as well get a kit for the fogs as well That would looks sooo sick. As long as it lights up the road as much as possible w/o blinding others its all good.
Old Mar 24, 2003 | 11:01 PM
E55AMG2's Avatar
Wat
Bimmers run 4300k, but they have projector lenses that refract the light to make it look more blue than it really is.
Old Mar 25, 2003 | 05:08 AM
NT2SHBBY
not to sure about the bulbs, but his ballasts are from Hella and are stamped Made in Germany
Old Mar 25, 2003 | 10:04 AM
SC2K1's Avatar
Has anyone used the misterjung conversion kit on a 2k or 2k1 halogen housing? I was looking at his kit and wanted to know how the install went and and how the beam/output levels were in comparison to the OEM 2k2 HIDs.
Old Mar 25, 2003 | 10:13 AM
NT2SHBBY
If it helps, I had his kit on my 2002 Altima and the beams were perfect....
Old Mar 25, 2003 | 10:18 AM
SC2K1's Avatar
I'm not familiar with the 2k2 Altima. Was it an H3 Halogen housing? Did you need to upgrade any of the wiring or fuses?
Old Mar 25, 2003 | 10:24 AM
2M0A0X2's Avatar
eeeexactly what I tried to say, but do people listen to me? no.
and has anyone ordered from Mr. jung? is he credible?
Old Mar 25, 2003 | 10:46 AM
NT2SHBBY
H1 housing.....no upgrade of the wiring, well actually I can't say that...everything needed comes with the kit. I had a professional shop install it for me (I have 2 left hands).
The fuses need to be upgraded to 20 amp fuses. The kit itself is plug and play. One end connects to the existing bulb housing and the other end gets plugged into the ballast. It's relatively simple to connect; my problem came when I had to drill the hole bigger for the wiring to fit through the existing "dust covers" which I was in no way prepared to do myself, thats why I had a shop do it.
As for Misterjung, he's credible. I have his personal phone number and address for those who want it. Alan (Misterjung) is a great guy. He might not answer emails right away, but he does read them and does respond sooner or later.
Like I said, I have his personal number for whomever wants.
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
