Need "urgent" help : from anyone who knows or has a service manual!
Just wiring up my S-AFCII and I'm missing one thing : which pin on the ECU is for the knock wire?
I've got the ECU diagram here that the noble Y2KevSE has posted numerous times but that one doesn't have it, and I'm not gonna trust a 4th gen ECU diagram
If someone can find the info for me, I'll paypal you a beer
Re: Need "urgent" help : from anyone who knows or has a service manual!
I have in pdf format....you have some place that I can upload it to?
Re: Re: Need "urgent" help : from anyone who knows or has a service manual!
FARK
I have my PC at home auto-checking my email so you can't even email it to me.. no FTP or anything at my disposal right now
I'm currently using my friend's shop to do this.. and now his PC (and I have no idea what his email addie is cuz he's not here).
Can you just give me the PIN # for knock as seen on the diagram? I don't care much for the rest...
Lemme know, I'll be checking - mucho gracias!
from the 2k1 FSM
CHECK KNOCK SENSOR INPUT SIGNAL CIRCUIT FOR OPEN AND SHORT-I
Check resistance between ECM terminal 93 and engine ground.
Wire Color W
Appears to be on the last row of horizotal plugs (5 horizontal plus 2 vertical on either side - it is the 5th, on the bottom right), 3 positions over from the last.
| ------- ------X-- |
I'm just relaying what I see.. I dont know anything about the procedure.. I hope it helps tho
Wire Color W
| ------- ------X-- |
Re: Re: Re: Need "urgent" help : from anyone who knows or has a service manual!
found this DTC P0325 knock sensor wiring diagram
ECM terminal # : 93
does this sound like the right one?
ECM terminal # : 93
FARK
FARK
Re: Re: Re: Re: Need "urgent" help : from anyone who knows or has a service manual!
Thanks guys, now I gotta figure out why the unit doesn't initialize
My car went from bad idle to not even starting
ECM terminal # : 93
ECM terminal # : 93
Thanks man - it's #93 all right... the problem that just popped up now is that I can't find a working ground : 2 of the 3 grounds I have NOW tried are not running any ground at all, and the other one turns on for a few seconds then shuts off
How many more grounds do you see on there?
I really owe you guys for this one
clicl me
I print-screened the pdf, check to see if this is the right one. then I will print it out of my printer and scan it back to the pc
clicl me
Fark
It's not the KS one I need to start the car, it's the MAF one
Makes me wonder wtf I'm having this problem with the ecupinout.jpg that's been going around.. I tried ALL the grounds there but none appear to be the MAF ground.
MAF ground anyone? I think I'm taking the bus home hah.
here is the scanned KS sensor wiring graph
alright jer...I gotta go. hope this will help.
tarun900
19
12-20-2021 06:57 PM
my03maxima
04-29-2020 12:48 AM
RealityCheck
10-02-2015 06:34 PM
