2000 Auto Max, No wheel spin?
Old Mar 25, 2003 | 09:02 PM
Max's Max's Avatar
Hey guys. I've had my 2000 max for about a month now. Well today I decided that I wanted to see just how fast my car could go 0 to 60. Light turns green and I step on the gas. Very little wheel spin. Is this normal. The car does not have traction control. Does this car have absolutely no low end torque? Could something be wrong or is this normal? Thanks
Old Mar 25, 2003 | 09:50 PM
BLaZin 2k MaX's Avatar
Your tires should cherp.
Old Mar 25, 2003 | 10:01 PM
[maxi-overdose]'s Avatar
Re: 2000 Auto Max, No wheel spin?
should've torque-brake @ 1700rpm.
Old Mar 25, 2003 | 11:21 PM
HitManSE's Avatar
Yeah its normal, the 2000-01 auto max's are the slowest next to the VG 3rd gens. Kinda disapointing isnt it, I got the same problem so ur not alone Its not slow just compared to the 5spd 4th gens, and the 6sp 3.5's they are.
Old Mar 25, 2003 | 11:32 PM
Y2KSESteve's Avatar
It's all in how you launch. I can launch all day without spinning my tires and still having a good start. Practice what works best with your car's power and tires and you'll get the same results. John you have that problem cuz you're running on slicks.
Old Mar 25, 2003 | 11:37 PM
HitManSE's Avatar
Yeah u gotta point, plus I hate to brake torque. Ill be runnin on new Yoko's soon. I canned the rims idea, I got the green light to get the 2K3 just gott hold off for a little while. Btw did u get that grill in or what?
Old Mar 25, 2003 | 11:40 PM
Y2KSESteve's Avatar
Grille project fell through. on the 2k3! My moms gettin one of those also.
Old Mar 25, 2003 | 11:57 PM
HitManSE's Avatar
She gettin 6spd too.
Old Mar 26, 2003 | 12:22 AM
slickrick's Avatar
i can take off slow then mash the throttle at 3500 and it will chirp to 5800. but i have a 2k2 auto with ****ty potenzas.
Old Mar 26, 2003 | 01:36 AM
andrew3616's Avatar
00-01 maximas are the fastest maxima 3.0 liter, the ones w/16inch rims. Just read the battle of the 3.0l
Old Mar 26, 2003 | 04:53 AM
Maxman2000's Avatar
On my max, I step on the gas and it peels out.
Old Mar 26, 2003 | 09:02 AM
awsker's Avatar
Same here. I mash the gas and I hear the wheels without torque breaking.
Old Mar 26, 2003 | 09:29 AM
Cutler's Avatar
My 2k can do it, but I don't try. I did it once at a light, and I have the 17s and it spun no effort
Old Mar 26, 2003 | 09:34 AM
EJH Y2K SE's Avatar
My Y2K auto will spin just fine...
What is the issue between the 16" rims and the 17" rims? Mine has the 16" rims and seems to be quick enough. I'm not a stop light racer anymore (thank god you mature with age).
Old Mar 26, 2003 | 09:36 AM
jjs's Avatar
jjs
Actually alot of factors can affect this...
tires (which type)
inflation
ambient temperature
road surface construction
etc.
Old Mar 26, 2003 | 06:52 PM
MONTE 01&97 SE's Avatar
They will chirp depending on the tires but just dont expect what see in the 02/03 auto's which will burn up some tires. You should be glad you dont get alot of spin because you will be outta their while som other guy is spinning his tires! Also the 92-94 VE auto are slower than the 00/01 autos, 95-01 are pretty much even with bettr low end for the 95-99 and better high end for the 00/01. The 02/03 auto sent the auto Maxima into a different league in acceleration.
Old Mar 26, 2003 | 07:00 PM
THill5thGen's Avatar
I have to say that I completely disagree with everyone.
I can spin the wheels on my 2k auto NO problem, with the TCS off I can mash the pedal (not even that hard) and the car won't be going anywhere for a while witht he tire spin.
When the TCS is on, if I mash the pedal, I can make the TCS have trouble with the torque without much problems. I'm pretty sure I don't have a freak Max, so I don't understand what other ppl are talking about.
Old Mar 26, 2003 | 08:59 PM
Max's Max's Avatar
Anyone ever try this with their factory potenzas? I have the 17 inch 6 spoke wheels. I was very shocked in this autos performance. I just traded my 94 grand prix which had much lower torque and horse power but it always seem to lay some rubber. BTW i got my blown away by an integra on my way home from work. Going about 70, looked in the rear view noticed that he was going to go in the right lane that was ending, I punched it an he just flew by me. It took a while for me to catch up to him. The car has just a little over 28000 miles. Was the car like this when it was new?
Old Mar 26, 2003 | 09:26 PM
95emeraldgxe's Avatar
what kinda tires do you have? tires play a big role in wheelspin too
Old Mar 26, 2003 | 09:33 PM
Y2KSESteve's Avatar
Mashing the gas pedal is not the best way to launch.
Old Mar 26, 2003 | 10:41 PM
thomasd cook's Avatar
At 28,000 miles you are close enough to change your plugs. I'm at 35,000 and my car felt very sluggish before I changed my plugs. My old plugs were fried. Just a suggestion but if you dogged your car out when you first got it then I'm sure it took a pretty hard toll on the plugs.
Old Mar 27, 2003 | 06:49 AM
wantasupra3's Avatar
I put better tires on mine..i get no wheel spin and better launches!!!
Old Mar 27, 2003 | 07:41 AM
bigdo26's Avatar
been spinnin the tires all winter. not as bad in the warm weather, but definatly cant floor it off the line. tried that when i first go the car and nothin but sqealin tires!
Old Mar 27, 2003 | 07:59 AM
tecman4's Avatar
Can someone explane what torque-brake means?
What would happen if you put the car in neutral and slammed the gas and then put it into drive?
Wayne
Old Mar 27, 2003 | 08:02 AM
Cutler's Avatar
To make a auto spin, do this.....
Put it in neutral, rev it to redline and hold it(will bounce off rev limiter), this will help make your A/F mixture nice and rich, thus giving the car more torque. Then slam the tranny in 1, this will cause a violent jerking motion and may produce some wheel hop. The car will start spinning and doing a nice burnout, if you armorall the tire tread this will make it nice and slick thus allowing you to spin into second while smoking the tires.
Do this and you will be the envy of all your friends
This is meant to be a joke and Jason will not be held responsible for any damage to your tranny and I have never attempted this and don't recommend it
Old Mar 27, 2003 | 08:11 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: To make a auto spin, do this.....
dank4us
34
Jun 10, 2024 03:45 AM
homeyclaus
Sep 3, 2015 06:15 PM
rbaker100
Aug 31, 2015 11:09 AM
jholley
Aug 11, 2015 09:38 AM
RealityCheck
Aug 5, 2015 06:18 AM
