Did my Frankencar, have some questions.
Old Mar 29, 2003 | 09:55 PM
Greek to the Max's Avatar
1. I only received 2 rubber couplings. Should'nt I have 3? I used the stock rubber plenum after the throttle body. At least it worked.
2. When all was said and done, teh filter sits up against the battery wire power wire. Very tight. Should I adjust the power wire?
3. The rings that came from the kit, seem to never want to tighten enough. They keep on turnign and turning. Anyoen else find that normal?
Any advice from anyone would be appreciated.
Thanks.
BTW, its loud as MF H.E.L.L
Old Mar 30, 2003 | 02:10 AM
Y2KSESteve's Avatar
Re: Did my Frankencar, have some questions.
Thanks.
Not the greatest picture, and not for your engine, but you get the idea. Two couplers is all you really need.
Old Mar 30, 2003 | 08:08 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Re: Did my Frankencar, have some questions.
is that the filter that comes with the frankencar? if not, then what is the part number on it? thanks.
Old Mar 30, 2003 | 08:18 AM
I have the apexi filter. So apparently you need 3.
Old Mar 30, 2003 | 09:49 AM
maximamaybe's Avatar
Here is what mine looks like on a 2002 MAX.
You should have 3 couplers if you have the Apexi Filter.http://images.cardomain.com/member_i...72_15_full.jpg
Old Mar 30, 2003 | 10:01 AM
Yes, i know for sure im Missing 3rd coupler. Once i get that in, my intake should fit much better. Thanks for the pic, we did alot of things teh same.
Old Mar 30, 2003 | 10:02 AM
KLOOGY's Avatar
L33t BMW Drivah
Thats what it should look like .
Old Mar 30, 2003 | 10:04 AM
max...to the ma's Avatar
just curious what does "MF H.E.L.L" mean exactly?
I noticed you guys used bolts and nuts on your MAF. Mine never came with the nuts, should i go buy some?
Old Mar 30, 2003 | 10:06 AM
***** Truckin Hell.
Old Mar 30, 2003 | 02:17 PM
ToasterMax's Avatar
arent you missing that bar on yours??
Old Mar 30, 2003 | 03:12 PM
03BlkSETE's Avatar
He's using a modified midpipe without a breather tube. He's using a crankcase filter instead which you can see in the picture.
Old Mar 30, 2003 | 03:31 PM
jimz02max's Avatar
Does that work better than with the tube?
Old Mar 30, 2003 | 03:36 PM
Y2KSESteve's Avatar
Might keep your MAF from failing as quickly...
Old Mar 30, 2003 | 04:03 PM
jimz02max's Avatar
Really!! Where do you get the breather? Do you have to use a different midpipe?
Old Mar 30, 2003 | 07:27 PM
KLOOGY's Avatar
L33t BMW Drivah
I got the breather at Pep Boys....The midpipe is different.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Mahmuth
Sep 25, 2015 10:08 AM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
