Franken Car, JWT and MAF
Old Mar 30, 2003 | 09:56 AM
gmangda's Avatar
I installed my Frankencar midpipe and JWT pop carger this weekend. I also installed a new MAF assembly because I broke the original one trying to take off the stock air box a week ago. Now that it's done I'm getting the SES light and a slight loss of power. Seeing that this is a new MAF assembly that came with a new meter shouldn't everything just work? I left the battery cable off over night to see if it reset the ecu but the light came back on after driving for ten minutes. Also I tried the MAF meter from the broken assembly and I'm having the same problem. HELP!!!!!
Old Mar 30, 2003 | 11:05 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Franken Car, JWT and MAF
i would drive the car to autozone or somewhere that pulls codes for free. make sure its the maf, because if its bad then you wouldnt be able to rev it over 2500 rpms. did you plug the air temp sensor into the midpipe?
Old Mar 30, 2003 | 12:20 PM
gmangda's Avatar
Yeah I did plug the ATS into the midpipe. I also think that it's all in my mind about the power being less. So I'll try autozone for them to pull the codes. So far I'm loving the sound of the intake and the midpipe
Old Mar 31, 2003 | 06:14 AM
gmangda's Avatar
Okay, here's the deal I went to Autozone this morning and the ODB code was P0105. It means that my MAP sensor is bad, now I have no idea what this is or what it does or how hard it is to install. Do I need to go to nissan to get this done? Is this a common problem like the MAF's?
Old Mar 31, 2003 | 10:52 AM
gmangda's Avatar
^^^BUMP
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
