Car hesitating to start
Old Mar 30, 2003 | 07:10 PM
00MaxSE's Avatar
Pointy Elbows
Today after work, my car wouldn't start up right away. It cranked over for like 2 seconds and then finally started up.
Can anyone tell me what's wrong with my Max?
Old Mar 30, 2003 | 07:12 PM
SR20DEN's Avatar
VQ Wizard
Re: Car hesitating to start
Fuel rail leak down. Usually caused by a leaky injector or failing FPR.
If it gets progressivly worse get in the habit of turning on the ignition for 3 seconds before you start the engine. That will give the fuel pump time to prime the rail.
Old Mar 30, 2003 | 10:18 PM
ojman's Avatar
Re: Re: Car hesitating to start
Woudl a fix on something like this be covered under the original warranty? I'm still under bumper to bumper and am experiencing this problem as well.
Old Mar 30, 2003 | 10:58 PM
bigmaxx
Maybe the starter is going bad? Did the starter sound like it was struggling or the engine just wasn't turning over?
Old Mar 31, 2003 | 04:57 AM
SR20DEN's Avatar
VQ Wizard
Re: Re: Re: Car hesitating to start
You could check into it but as usual the Nissan technicians may not know how to figure it out and tell you there isn't a problem. Let's hope that isn't the case.
Old Mar 31, 2003 | 07:49 AM
njmaxseltd's Avatar
A 2 Second crank...
Old Mar 31, 2003 | 09:07 AM
naerok's Avatar
This must be common. i also have this problem.
Old Mar 31, 2003 | 09:08 AM
Phoenix1911's Avatar
Your IACV maybe sticking and need to be cleaned or replaced? Throttle body?? If your starter isn't straining your just not getting the fuel neccesary to start her... I can't say I've heard of a leaky fuel rail? But who knows!
Old Mar 31, 2003 | 09:34 AM
vsmax's Avatar
i also have the same problem...after a 2 second crank it would start....same thing happened to Y2ksesteve in az...i thought i was the only one...
Old Mar 31, 2003 | 12:42 PM
Jakester's Avatar
I occaisionally have the same issue with my 2k1
Old Mar 31, 2003 | 07:36 PM
00MaxSE's Avatar
Pointy Elbows
Well it's good to know that I'm not the only one with this problem. Yeah, someone told me about turning on the ignition before starting. I try to do it once in a while. I've never had this problem before, but in the past it has started up, but not smoothly. It hesitated and almost acted like it was going to stall, but then started up to smooth idle.
Considering that my warranty is over with, I can't really take it in to get it fixed for free. I sure can't afford to pay to have it fixed right now.
Old Mar 31, 2003 | 09:17 PM
Max's Max's Avatar
I had this happen to me. I was told that the max loves to pure fuel into the engine during the initial startup. If you let go the key to early wait a few seconds before trying to crank it again. The engine will flood if you don't. If you flood the engine hold the gas all the way down to the floor and crank it. This will cutoff the fuel pump and burn the gas in the cylinders. Let go the gas once it cranks over.
Old Apr 1, 2003 | 04:32 AM
lcf's Avatar
lcf
TimW articulated this problem several months ago. Unfortunately I can't search for it.
Old Apr 1, 2003 | 10:10 AM
tonyg's Avatar
It happens to me
I experinced this after one month with my car back in April '01.I have an SE auto with 29k on it now. It happens to me sometimes when the car is warm, driven then re-started after about an hour.If I put the key in the ignition, wait a second or two, then engage the fuel pump for a couple of seconds before cranking, the car always turns over.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 7, 2015 04:20 PM
