Performance Muffler
Old Jan 16, 2001 | 04:50 PM
Dave Lopez's Avatar
Hey Guys, I know alot of you have performance exhaust systems on your Maximas i.e.......cat backs, y pipes, etc....,but do any of you have just the muffler with a tip????? I called Stillen today and they want $550 dollars for their rear section only!!!!! Ive seen in many performance magazines that there are universal mufflers on the market that will probably fit a 2000 Max for about $200 dollars. Do any of you have these? If so, what kind? I dont want anything overly loud, but i would like some gain in HP and a lil bit of an exhaust note. Thanks for your help!!!!
Old Jan 16, 2001 | 07:00 PM
Darrell's Avatar
An aftermarket muffler on the 5th gen Maxima will do nothing but make noise. The stock muffler is very well engineered and probably will give you more power than most of the aftermarket mufflers out there.
Old Jan 16, 2001 | 07:01 PM
y2kse's Avatar
I've been through several iterations of exhaust systems on my Max. If I had it to do all over again, I would have started by simply removing the stock resonator and replacing it with a piece of straight through pipe. That will probably cost you all of about $30.00. If you don't like the way it sounds, you can always put the resonator back on and you'll still be out very little money.
Replacing your stock muffler alone will not give you any increase in hp. The only reason to replace it with an aftermarket muffler is if you want even more of an exhaust note than you'll get by removing the resonator.
Try it. You'll like it.
Old Jan 16, 2001 | 07:45 PM
RBa's Avatar
RBa
$550 for just the muffler?! Damm! How much were they asking for the whole system then?
Old Jan 16, 2001 | 08:25 PM
DOM's Avatar
DOM
[QUOTE]Originally posted by y2kse
[I][QUOTE][i]Originally posted by Dave Lopez
So is this $30 pipe you are talking about the same as the b pipe? Would anyone make a pipe for that cheap?
Old Jan 16, 2001 | 08:57 PM
y2kse's Avatar
No. A B-pipe connects the catalytic converter to the rear section. It may or may not contain a resonator. My recommendation involves removing the resonator from the stock B-pipe.
Old Jan 19, 2001 | 05:40 PM
Dave Lopez's Avatar
Any of you guys using a Flowmaster muffler with a tip or any other type muffler?????
Old Jan 19, 2001 | 10:10 PM
RBa's Avatar
RBa
<B>No.<B>
Old Jan 19, 2001 | 10:15 PM
mingo's Avatar
i have tips welded onto my stock muffler.. i say if you aren't after the increase in power but want a deep tone coming from your exhaust get any universal muffler that u like. i personally think dual n'1 from apex wouldn't look too bad on a max.. or just a single one would be cool too tilted slightly to the side.
Old Jan 19, 2001 | 10:17 PM
MaximaRacer's Avatar
I have a performance muffler from Arospeed on my 4th gen max..it looks great and sounds great..you wont really get any performance gain from just the muffler but it sure does look nice. I got it for under $200 . If you are in the NJ/NY area email me and I can hook you up with a good deal.
Old Jan 22, 2001 | 01:23 PM
Dave Lopez's Avatar
Thanks for the info guys. Ill keep your ideas in mind.If any other of you Maxima Enthusiasts would like to jump in and give me advise, please feel free. The more info I get on this topic, the better! By the way, Im in southern california.
Old Jan 22, 2001 | 02:15 PM
y2kse's Avatar
The more info I get on this topic, the better! By the way, Im in southern california. [/i]
I'm also in So. Cal., Dave. One nice thing about living here is you don't need to use stainless steel in your exhaust system . . . except for looks, that is!
I've tried a couple of different mufflers. The first was a Dynomax Super Turbo (chambered design). The Dynomax was practically as quiet as the stock muffler. The next muffler I tried was a 24" Magnaflow (straight-through design). That's what I'm running now on my catback system. It sounds strong, not ricey, but it drones a little at low rpms (<2500 rpm). It's not obnoxious, however, and at cruising speeds (>2500 rpm) it's all but unnoticeable. In combination with the Stillen Intake, my car sounds mean as hell at WOT!
Old Jan 23, 2001 | 02:17 PM
Dave Lopez's Avatar
[/I]
Thanks for the reply y2kse! I recently went to a muffler shop in Glendale, and if I remember correctly, I believe the Magnaflow muffler was the one the owner was telling me about. He said it would run about $230 installed,including a flange. Where in socal are you y2kse? IM in Burbank. If you are ever in this area, I would love to hear what your car sounds like.
Old Jan 23, 2001 | 05:34 PM
y2kse's Avatar
Check your e-mail Dave.
GOOD LORD! $230.00 installed for a Magnaflow muffler is HIGHWAY ROBBERY! Call Mike at Mike's Mufflers in El Monte and get a quote. He installed a complete mandrel-bent catback system in my Maxima including a 24" Magnaflow muffler for $275.00! (The stainless steel tip was extra.)
Mike does excellent work. He can be reached at 626-443-5139.
Old Jan 23, 2001 | 08:27 PM
jkiMaX00
resonator from the stock B-pipe.????? HUH?
hey y2kse.. can u tell me how to get that out?? or if ne of u know a post that can help wiht that.. cusae i don't want to change my muffler.. i just want to leave it alone.. but taking that resonator out.. dose it make a lil bit more noise?? well fill me in.. n let me know if u can.. on how to get that out or replace it or some thing.. well fill me in ok y2kse... ?? ok.. thanks..
Old Jan 23, 2001 | 10:13 PM
y2kse's Avatar
Re: resonator from the stock B-pipe.????? HUH?
Ain't no big deal, jkiMaX00. Just find a local muffler shop and tell them you want them to remove the stock resonator. It should take them about 10 minutes to cut it out and weld a piece of pipe in its place. And it shouldn't cost you more than $30 to $40 to have it done.
Old Jan 24, 2001 | 05:12 PM
Dave Lopez's Avatar
Check your email y2k
Old Jan 25, 2001 | 12:40 AM
irvine78's Avatar
well....i know these don't say performance much...
but..serves the purpose and looks better than the stock ones...well, i think...
<IMG SRC="http://albums.photopoint.com/j/View?u=1377685&a=10279967&p=36115159">
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
Dasmith
Sep 23, 2015 08:28 PM
TheMafia
Sep 4, 2015 08:26 AM
