Pacesetter Sts Problems...
Old Apr 4, 2003 | 09:26 AM
max34's Avatar
I get a physical and audible pop when I shift out of 1st and out of 3rd...anybody else have this?
Is it loose?
Old Apr 4, 2003 | 09:38 AM
PCGuRu2K's Avatar
Re: Pacesetter Sts Problems...
Is it loose?
Does it sound like it banging something under the card? Might be hitting the heat shield..
Old Apr 4, 2003 | 10:43 AM
max34's Avatar
Re: Re: Pacesetter Sts Problems...
It's not a banging noise. I feel it click when I shift down.
Old Apr 4, 2003 | 11:56 AM
T-bone's Avatar
I am pretty sure that the 'click' is normal.
Old Apr 4, 2003 | 12:29 PM
irvine78's Avatar
i don't have that 'click' sound...
Old Apr 4, 2003 | 01:37 PM
Max_Gator's Avatar
Are you referring to the "notchy" feel of the shifter - i.e. you can feel it go through the gates?
There is a definite feel as the shifter goes into gear. I guess you could call it a click. Is that what you feel?
max34's Avatar
This is the first it's happened. I have had it for 2 years.
Old Apr 4, 2003 | 01:40 PM
Max_Gator's Avatar
You may want to check the linkage under the car and make sure all of the bolts are tight.
The only other thing I can think of is that the screw holding the ball to the rod has allowed it to come loose and that is somehow causing the sound/feel.
Old Apr 4, 2003 | 01:48 PM
max34's Avatar
thanks.
Old Apr 4, 2003 | 07:19 PM
asu174's Avatar
Clay Aiken has fancy genitals
My guess is that it's the ball popping a bit.
Wolvee
Aug 11, 2015 12:24 PM
97max5spd
Aug 2, 2001 09:15 AM
TarHeelMax
Mar 27, 2001 08:28 PM
ebb
Dec 4, 2000 11:32 PM
