new plugs.. wow, where to start!
Old Apr 6, 2003 | 09:44 PM
TimW's Avatar
The silent but deadly Moderator
I should have ordered from Dave, but I forgot to call him and really wanted to do it this weekend. So I paid the price, literally! $80 with tax from NAPA. ouch..
well, I was really beating myself about paying that extra $20 (with shipping)... until I finished and started the car! Oh my god... the first thing I noticed is that the car started in 1/2 the time... and that was after being moved, so I should have had a hard start.. not so, it started immediately.. no I mean instantaneously compared to regular starts. A few more starts were all the same, 1/2 the regular time.. My car has never started like that.
I took it around the block and it was pulling so hard. It was raining so I mainly broke tracting ALOT.. but I could tell it was really pulling harder.
AND FINALLY THE IDLE! smooth as hell.. I havent had an idle like that in 30K miles! AC/lights/fogs going and it was still smooth.. Every once and while I could feel a very subtle vibe, but nothing like the shuddering and loaping as before.
I guess the moral to the story is that if you had your coils replaced, then you may want to check those plugs too. Those bad coils really ate my plugs.. In fact, I think my plugs were toast at 10K. Only took me 30K more to realize it.
Old Apr 6, 2003 | 09:54 PM
Y2KSESteve's Avatar
I need to do this so bad.
Old Apr 6, 2003 | 10:55 PM
slickrick's Avatar
i like happy endings.
Old Apr 6, 2003 | 11:15 PM
TimW's Avatar
tell me why my keyless entry freaked out and it will be a truly happy ending :/ I reset (neg term off the battery) and it got better for awhile, not its not reponding again.. well, intermittant. *everything* else on the SECU seems to be fine. Bizarre.
Old Apr 7, 2003 | 12:37 AM
[maxi-overdose]'s Avatar
there is a huge diff. btwn copper and plantium.
I replaced mine 2 weeks ago. I went with copper, 1.59 each. if you dont mind gapping it every 15 - 20k miles, it saves a lot.
Old Apr 7, 2003 | 04:28 AM
Maxman2000's Avatar
. I found that funny.
Old Apr 7, 2003 | 06:42 AM
UMD_MaxSE's Avatar
Got Bent?
told you changing them would fix all your problems... hehehe...
Old Apr 7, 2003 | 07:04 AM
maxman00's Avatar
What plugs did you go with? I only have 30k on my car, but I keep hearing good things about replacing the plugs. I might have to do it soon!
Old Apr 7, 2003 | 07:37 AM
TimW's Avatar
I got the platinum.. however, now knowing how easy it is to swap them, it would be nothing to go copper and replace them every 30K. But its nice to know I wont have to worry about these for awhile (platinum), as my car has shown itself to be VERY hard on plugs.
Old Apr 7, 2003 | 08:26 AM
saxdogg's Avatar
this may sound dumb....but
Have you tried replacing your remote battery? Maybe? Just maybe???
Go plugs! Glad it worked. I just replaced all the plugs and wires on my Ford. It's idle still sucks a$$.
ARFF
Old Apr 7, 2003 | 08:28 AM
TimW's Avatar
nope, not the batteries. something is really freaked out. Of course the dealer will probably blame the HIDs
Old Apr 7, 2003 | 09:10 AM
very hard on plugs? did you notice any damage on it? when I took out mine, I noticed that insulator was really white because I was running lean. Other than that, the gap was .038 instead of factory .044. Now I am running 1 step colder copper with .038.
IMO, I hated to replace the plugs on the rear bank. I had to remove some bracket to get to cylinder no. 5. after replacing them, my back was hurt and I was sweating like a pig.
other than that, I followed Hayne's manual and used a 8mm fuel hose to insert the plug back in. I would easily notice if I crossed a thread this way.
Old Apr 7, 2003 | 09:36 AM
TimW's Avatar
Most of my plugs were mushroomed at the tip like this one. Not really bad for a plug, but not in great shape either.
I just moved those cables out of the way on the rear. As far as the plugs going back in, I used the extension and plug socket. I turned it backwards a few turns, then forward. After a few turns, I pulled on it an made sure the plug was threaded in.. then continued finger tightening to the gasket... then popped on the torque wrench. My only shame is that I needed to stand on a block to get to that last rear one.. Being 5'10" can suck..
At last (driver side rear bank) was tough.. I used a 11" extension -> wobble ->6" extension. On torqing, I was *very* careful to keep the extension centered in the hole (when using the unversal joint).
Old Apr 7, 2003 | 10:10 AM
how many miles you have on it? that maybe the result of the bad coils you had. let me show you my pictures after work.
I had to loose the bracket that holds the throttle and cruise control cables. I had problem taking them out when the bracket is still attached.
I guess it was a bit easier for me because my car is lowered. I am 5'9, btw. I bet Kevin has no problem with it at all.
that's the tough one, cynliner no. 5, the last one the fuel rail. I had a bad 11" extension in the beginning. It was a 1/2" extension so I had to use 3/8" to 1/2" socket to connect this extension to the spark plug socket. It kept falling off my wrench and I had to use a magnetic rod or a plier to take out the socket everytime. Finally when I readjusted the gap on the next day, I went to buy a good 3/8" extension.
it is good to work on the car during the night, you get hella tired when it is done and you go straight to a good night sleep.
Old Apr 7, 2003 | 10:26 AM
Igor911's Avatar
Tim - what plugs did you use? Nissan stock?
Old Apr 7, 2003 | 01:36 PM
TimW's Avatar
you can use the part number and get them at any napa.. same plug.. but you will pay 50% more than using DaveB
Old Apr 7, 2003 | 01:49 PM
karguy's Avatar
Re: new plugs.. wow, where to start!
I guess the moral to the story is that if you had your coils replaced, then you may want to check those plugs too. Those bad coils really ate my plugs.. In fact, I think my plugs were toast at 10K. Only took me 30K more to realize it. [/B][/QUOTE]
I replaced my plugs with OEM NGKs at 50K and had similar results although I did not have coil problems. I have now decided on replacing my plugs every 40K. If you run them longer I think any projected savings go out the exhaust pipe.
Old Apr 7, 2003 | 03:48 PM
K Pazzo 6's Avatar
i'm going to change my plugs too when it gets nice out here in chicago....one question though-- what did u torque it to? thanks
Old Apr 7, 2003 | 04:02 PM
17 - 22 lb/ft
Old Apr 7, 2003 | 04:59 PM
K Pazzo 6's Avatar
Originally posted by [maxi-overdose]
17 - 22 lb/ft
thanks
Old Apr 7, 2003 | 06:07 PM
thanks
np..dont set it too tight because you have anti-sieze on it. with anti-sieze, the torque reading will be a bit lower.
Old Apr 7, 2003 | 06:13 PM
karguy's Avatar
I reduce torque by 1/3 when using anti seize compound so as to not overtighten anything!
Old Apr 7, 2003 | 07:49 PM
TimW's Avatar
I assumed the NKG's already had some sort of antiseize film.
Old Apr 7, 2003 | 08:01 PM
DAVEB's Avatar
Nope- NGK's are dry as a bone- Gotta slop on the anti-seize!
Old Apr 7, 2003 | 09:19 PM
TimW's Avatar
great do I need to pull them out right away? or can I go for a week or two without?
Old Apr 7, 2003 | 10:25 PM
I tried a week or two without it.
it will just get tighter and tigher after more use and abuse.
Old Apr 7, 2003 | 10:30 PM
http://home.earthlink.net/~doctorkiwi/SC/P1010126.JPG
my spark plug, 43k, 9k boosted miles.
Old Apr 7, 2003 | 10:32 PM
TimW's Avatar
lean and clean!
Old Apr 7, 2003 | 10:40 PM
lean and clean!
yup, I was running lean for a while.....see how white the insulator is.
Old Apr 8, 2003 | 06:40 AM
DAVEB's Avatar
You could definitely go a week or two without it, just don't leave 'em in forever!
Old Apr 20, 2003 | 11:32 AM
MadXtreme01's Avatar
just replaced my plugs, damn they were expensive, i got the denso irridum's, but well worth the money for them, the worst part id have to say was the pain in the *** to install, but at least we dont have to replace wires too
spazma7ik
Jan 12, 2017 09:38 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
