Fuel Cutoff TSB
Old Apr 8, 2003 | 11:33 AM
Phoenix1911's Avatar
Fuel Cutoff TSB
Sorry to bring this old one up again, but in the FAQs there doesn't seem to be a conclusion to this TSB.. Nissan attempted a fix but there were mixed results. Anyone know if this TSB ever fixed the bucking??? I'm still not sure what the symptoms are??
When my car (2000 SE 5spd) is cold (especially below freezing), I get a bucking around 2000rpm for a few minutes. So for the first few minutes I keep her at 2500 rpm+, or 1500 & below (idle etc)... Once its been driven for a few minutes she runs perfectly fine.... I've read the whole thread and am still a little uncertain of this TSB..
Anyone care to shed some light here???
Old Apr 9, 2003 | 08:39 AM
noone had this TSB done, or looked into it since 2001??
Possibly the bucking is clutch chatter?? i don't know what clutch chatter is... anyone?
Old Apr 9, 2003 | 10:24 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Just do it!
TSB threads:
http://forums.maxima.org/search.php?...der=descending
Old Apr 10, 2003 | 11:22 AM
I would but I think I need more info on what the exact TSB iz... none of the links work anymore...
The one thing that REALLY glares at me here is that noone said it went away after the engine heated up... Mine only does this cold for a few minutes when at around 2000rpm...
Old Apr 10, 2003 | 11:56 AM
IceY2K1's Avatar
Are you complaining about the low speed parking lot bucking?
It doesn't go away 100%, however the TSB makes it MUCH much better.
What you are referring too still happens when the ECU artificially holds the RPMs up while cold. I just don't let off the throttle withOUT pushing in the clutch FIRST. You have to modulate the clutch until the RPMs come down from 1300 or so to 650. After the first decrease by the ECU to ~900rpms, it's no where near as touchy. I'll usually wait until the ECU kicks down to 900 RPMS before I drive off.
My biggest remaining gripe is when I'm going slightly downhill at say 50mph and the car is accelerating, so I let off to maintain speed and get a MAJOR buck everytime I reapply throttle. If I drive it like a stole it, I never notice, however when I'm cruising and constantly let off the throttle/reapplying throttle, that is when I get the bucking.
Old Apr 10, 2003 | 03:34 PM
MS 2K1 AE's Avatar
Re: Fuel Cutoff TSB
Ignore the symptoms when the car is cold. It could be a combo of things then. However, when warm, the TSB will drastically reduce bucking. I had it done on my '01 and there was major improvement.
I don't know which of the 300 threads you were able to read on the issue , however, the best test to determine if you need the TSB is this:
While stopped and in nuetral (or in gear with clutch fully depressed), try to hold the engine at 2500 RPMs. In my car, I could never do it. If you gave a touch of gas, the RPMs would shoot up above 3K. If you let off the gas a hair, RPMs would drop down to idle. It was impossible to hold any steady RPM between 2K-3.5K.
This made it really hard to get a solid launch while in racing mode
There were several other tests, but the concensus was that this was the best. I highly recommend the TSB, it made a world of difference in daily driving for me.
Old Apr 10, 2003 | 05:36 PM
I'm fairly certain I can hold an rpm in the 2k-3.5k range at idle no problem.... The bucking feels like... well bucking..... like a machine gun?
Old Apr 10, 2003 | 07:56 PM
Rich96's Avatar
I have an 00 5 speed and had the TSB done.
If I don't let my car warm up and its cold out I get the bucking.
Not sure what causes it.
Old Apr 11, 2003 | 09:18 AM
... If I drive it like a stole it....
Actually that parking lot one may be more it! Where I goto the gym, the parking lot is sortof a two story thing and I park on the roof, its on a bit of an angle, but I thought the ground was just lumpy, but I had a good look and its flat but just a bit of throttle in 1st the car was sortof jerky and the gas pedal VERY touchy, this roof is the only place I've experienced this, and again its on an angle...
When its cold and I'm on the gas I only get the bucking when I start to come off the throttle without pressing the clutch... if I get back on the gas I need to bring it up a couple hundred rpm to get the bucking to go away... if I rev up to 3000+ before shifting cold, there are no problems... But I want to be easy on her cold, and thats the problem... Once shes warmed up it runs perfect...
Maybe that parking lot thing though is an issue, I'll have to experiment... Does anyone have a pdf or jpg of the TSB?
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
