Extremely rough starting this morning
Old Apr 9, 2003 | 08:11 AM
Cabowabo's Avatar
I went out to start my car this cold, rainy morning when the unexpected happened. When I cranked the car over, it started but then stalled after about 3 seconds. I then went to crank it over again and it wouldn't start. I tried 3 times and on the last attempt I just kept cranking because it sounded like it was just about there. I backed off and the max was running but running extremely rough for about 5 seconds and then it started running fine. I let it warm up for about 5 minutes then shut it off and it started right up again without any problems.
Any Ideas what might have happened? Bad gas?
Cabowabo
'02 max se
Old Apr 9, 2003 | 08:16 AM
Maxman2000's Avatar
Could be bad spark plugs.
Old Apr 9, 2003 | 08:34 AM
bobcat's Avatar
I had the same thing happen to me 2 or 3 months after I bought my car. It hasn't happened since so I guess it wasn't anything. Could just be bad gas like you said. If it does it again I'd take it to the dealer otherwise I wouldn't worry about it.
Old Apr 9, 2003 | 08:35 AM
njmaxseltd's Avatar
Cold damp morning, lots of moisture, dense air. It probably started, fouled out slightly do to the dense cold moist air. Then upon restart, being it was fouled a bit with excess gas, it had a hard time, then cleared up. Believe it or not, your car may not run perfect 100% of the time. Even I have a hard time getting out of bed on mornings like that.
Old Apr 9, 2003 | 08:37 AM
NT2SHBBY
cars are people too, ya know
Old Apr 9, 2003 | 08:50 AM
Cabowabo's Avatar
Thanks for the replies.
I've just never had that happen before on any new car I've had in the past. I just get a little suspicious of this car because a couple of months ago I had an issue where the car lost all power. I gave it gas and it would go nowhere at all. It felt like when you mash the gas when your doing 30mph in 6th gear but I wasn't in sixth, I think I was in 2nd. Next time I started the car, it was fine, like nothing ever happened.
I was planning on keeping this car until it blows up but there's some weird stuff going on with it every once in while that I think a car with 16K miles should not have.
Cabowabo
Old Apr 9, 2003 | 09:11 AM
Maxman2000's Avatar
Exactly.
Mar 12, 2020 12:06 AM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
