Cattman / Progress RSB - installation Question !!!
Old Apr 12, 2003 | 07:56 PM
max2k1SE's Avatar
Folks:
Am going to install the Cattman/Progress RSB tomorrow.
I read the install instructions and some threads here about the install - there was nothing mentioned about how "tight" you need to torque the linkages - bolts etc.
The package has "locking" nuts for the U-bolt and the bushings/brackets.
I don't have a torque wrench - do I need one for this ? ( I don't plan to take off the wheels - using ramps ! ).
Is it OK to tighten is as much as it will go ?? Anything messes up by over-tightening this thing ?
Any ideas ?
Thanks - it will be good to get some inputs before I actually do this tomorrow
Old Apr 12, 2003 | 08:03 PM
00SEinMA's Avatar
I'm pretty sure that because they are rubber or polyurathane bushings that go around the bar, you should tighten them as much as possible. That what I did and it hasn't been a problem yet, with about 8000 miles on the bar.
-James
Old Apr 12, 2003 | 08:05 PM
max2k1SE's Avatar
Thanks -- those are polyurethane in fact.
What is a locking nut anyways ?
Old Apr 12, 2003 | 08:10 PM
00SEinMA's Avatar
no clue... it's realy not a hard install at all... one of the U pieces didn't fit and I had to bend it out... but other than that I didn't even lift my car up... only took about an hour even with the problems... don't sweat it, and it'll put a huge on your face when it's all set and done.
-James
Old Apr 12, 2003 | 08:29 PM
KennyLau
Re: Cattman / Progress RSB - installation Question !!!
Just tighten everything as much as you can. You don't need a torque wrench.
After I first installed my Cattman/Progress RSB, everything was nice and tight, so performance was great. But it loosened up on me and I didn't even think about how the car was handling. Then earlier this week, I decided to tighten everything up, and after driving, I was like...OMG!! It really makes a difference to keep that thing tight.
My Maxima is so much more fun to drive now that I feel the full effects of the RSB.
Old Apr 12, 2003 | 08:35 PM
max2k1SE's Avatar
Thanks folks --- so does the RSB need really periodic tightening ?
Maybe once every 5K miles or so ?
Old Apr 13, 2003 | 11:51 AM
00SEinMA's Avatar
I just tried to tighten mine about a week ago or so, and all the bolts were just as tight as when I first put them on, except for one. So I do recomend to check twice a year or so and tighten as necessary, but it shouldnt be much of a concern.
-James
Old Apr 13, 2003 | 08:18 PM
Maximax2's Avatar
I tightened mine up after the first week, and they're still tight 4k miles later. It's worth checking - a while back someone posted that their RSB bolts had come loose to the point of degraded performance, but that's the only time I've heard it.
Old Apr 14, 2003 | 11:06 AM
max2k1SE's Avatar
Install Success !!!
Folks :
Thanks for your timely comments and suggestions .... I managed to install this on Sunday and it was indeed painless
Didn't take very long and the instructions I got from the org was more than sufficient for the task !
I still haven't managed to push it much to test the RSB -- Monday morning commute sucks
One question though --> the parking brake hose clamp- that had to be removed to fit the saddle -> I was *not* able to put the clamp back on - the hoses were not hanging loose - I guess this is OK ?
Let me know if this is not so !
Old Apr 16, 2003 | 11:52 AM
max2k1SE's Avatar
Re: Install Success !!!
Anyone knows it its OK to leave the e-brake cable clamp as is ?
Old Apr 22, 2003 | 11:39 PM
Yoogie's Avatar
I finished installation of this bar today and it went fine. I was able to re-install the e-brake clamp by starting the 10mm bolt and then bending the clamp out as I tightened it up. I also cut the ABS wire braket such that I could install it in two pieces and retain both of the clamp locations for the wire. Installation almost looks like it came from the factory.
I am a believer in the RSB now as well. I took the car around a couple of very well known curves I drive and what a difference! Highly recommened.
Old Apr 23, 2003 | 06:04 AM
Jakester's Avatar
This whole thing about loosening bolts got me thinking. Besides the Max, my other hobby is firearms, and, when I put a scope on a new rifle I will use loctite on the scope ring screws, when it sets it does not come loose, even with the vibration/shock/recoil of a .50 Cal rifle, would this work on something like the rsb bolts?
-J
Old Apr 23, 2003 | 11:36 AM
max2k1SE's Avatar
Yoogie:
Any pics of what you did to the clamp ?
My e-brake cable clamp is not attached to the trailing arm - I've not had a problem - but it'll feel nicer to have it back up
Cotozic
Jun 28, 2017 08:01 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Aug 27, 2015 12:01 AM
Maxboy23
Aug 20, 2015 09:33 AM
