SAFC-II install on a 2002 Max
Old Apr 12, 2003 | 10:25 PM
SR20DEN's Avatar
VQ Wizard
First, Speacial thanks to Dixit (BigDogJonx) for looking through the 2k2 FSM and giving me all the pinouts I needed. And providing me with the AFC-II wire coding. I can't read the Japanese manuals. Thanks also goes to Scott for providing me with the ECU diagram he rounded up for his AFC-II install.
Today I installed the SAFC-II on my 2002 Maxima. So far it just looks like a neat gadget to have in the car (it kicks ***!)but I hope it will be a useful tuning tool for MAF and injector upgrades. I have taken pictures of the install step by step and will post them sometime late Sunday. Maybe even a few low grade videos of the thing in action. But I still need to attach the knock sensor wire and the primary O2. I plan to do my initial tuning from the readings I get from my A/F gauge. After I learn every nook and cranny of this thing I'll take the car to the dyno and tune.
Old Apr 12, 2003 | 10:29 PM
Donkey®'s Avatar
wat
Re: SAFC-II install on a 2002 Max
CONGRATS and thanks for the step by step stuff to come. Enjoy the new toy! (Black screen is PHAT damn it!!!!)
Old Apr 12, 2003 | 10:30 PM
SR20DEN's Avatar
VQ Wizard
Here is the word document that I got from Scott. I have added the missing pinouts and the SAFC-II color codes I got from Dixit.
Old Apr 12, 2003 | 10:50 PM
BigDogJonx's Avatar
Glad you got it working.
Dixit
Old Apr 13, 2003 | 06:19 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Now put on a coffee can muffler and you can be too.
Old Apr 13, 2003 | 07:48 AM
chinaonnitrous1's Avatar
i gotta get me one o thoes Apexi toys.... I need more digital gizmos inside.
Old Apr 13, 2003 | 08:06 AM
SR20DEN's Avatar
VQ Wizard
I am trying to avoid that like the plague.
Old Apr 13, 2003 | 11:30 AM
SR20DEN's Avatar
VQ Wizard
A few pictures I took last night of the butchering.
Old Apr 13, 2003 | 11:59 AM
Jer's Avatar
Jer
I think mine will be for sale soon considering my 1 car seems to be the only one on this planet with the wires all different from all the FSM's I've gotten my hands on
Black is pink for me, red/green is orange, etc... sigh
Anyone wanna trade ECU's? lol....
Old Apr 13, 2003 | 01:28 PM
HitManSE's Avatar
Niiiiiice....
Old Apr 13, 2003 | 03:26 PM
TRuFLiPpeR's Avatar
yeah, i donated....so?!?
helpful!
this will be very helpful. please, when you tune, could you post results? i plan on doing this same install as well. i had the V-AFC for my integra and it worked wonders! thanks!
n1cK!
Old Apr 13, 2003 | 05:34 PM
PCGuRu2K's Avatar
Does this doc apply to the 2K1's as well? I plan on getting the limited Edition Safc-II also
Old Apr 13, 2003 | 08:46 PM
BigDogJonx's Avatar
No No, this doc is clearly only for 2k2-2k3, their wire colors are different as well as pin locations.
Use the standard Pin setup that Kev has up for the SAFCI, its the same setup, only extra pin you need is the knock sensor which is basically a White or Clear wire off Pin93 of the ECM.
SAFCII Wire Codes
Red - power
Green - rpm signal
Gray - Throttle signal (TPS)
Brown - Ground
Black - Ground
Yellow - A/F Output (this goes towards the ECU)
White - A/F Input (goes away from ECU)
Blue - can be used as O2 sensor voltage meter. Hook up to one of the primary O2 leads.
Pink Not used (Used on Karman vehicles)
Orange Not used (Used on Karman vehicles)
Purple - Knock
Dixit
Old Apr 13, 2003 | 08:51 PM
PCGuRu2K's Avatar
SAFCII Wire Codes
Red - power
Green - rpm signal
Brown - Ground
Black - Ground
Purple - Knock
Dixit
Cool. Thanks!
Old Apr 13, 2003 | 09:10 PM
SR20DEN's Avatar
VQ Wizard
SAFCII Wire Codes
Red - power
Green - rpm signal
Brown - Ground
Black - Ground
Purple - Knock
Dixit
It was the clear wire. You told me white.
I finished it today.
Old Apr 13, 2003 | 09:15 PM
BigDogJonx's Avatar
I know I went back and forth 3x on mine cause I couldnt figure out it why the FSM shows White but it is clear.
Dixit
Old Apr 13, 2003 | 09:16 PM
SR20DEN's Avatar
VQ Wizard
Dixit
I did the exact same thing. I counted it and checked the notes 5 times.
Old Apr 14, 2003 | 06:50 PM
SR20DEN's Avatar
VQ Wizard
I put the 3" PVC MAF back on yesterday. It's taking some weird tuning curves but appears to be finally settling correctly.
This thing is LOUD! The butt dyno seems to approve but I will make no guesses as to what if any hp increase. The Humblemaker will reveal all.
Old Apr 14, 2003 | 08:57 PM
00MaxSE's Avatar
Pointy Elbows
What exactly did you do? What is an AFC-II? What does it do? Sorry, I know nothing about this stuff.
Old Apr 15, 2003 | 04:34 AM
BigDogJonx's Avatar
Re: Re: SAFC-II install on a 2002 Max
An SAFC and SAFCII are basically Airflow signal manipulators. It allows you to fine tune the air/fuel curve on your car better when you are using forced induction. Most of todays car computers can handle the a/f curve fairly well without forced induction, but once you introduce that, it doesnt hold the curve to maximum HP output. This is where the SAFC comes in play.
Now you can use it against Non-aspirated cars, but the gains are almost nill unless your curve is off like bigtime. If thats the case then you have other problems on the car.
Dixit
Old Apr 15, 2003 | 05:08 AM
Donkey®'s Avatar
wat
Does this mean that the document you made needs to be updated some more?
Old Apr 15, 2003 | 05:18 AM
SR20DEN's Avatar
VQ Wizard
Re: Re: Re: SAFC-II install on a 2002 Max
Non-aspirated carsDixit
Thats Naturally Aspirated.
Old Apr 15, 2003 | 05:43 AM
Donkey®'s Avatar
wat
Re: Re: Re: Re: SAFC-II install on a 2002 Max
Thats Naturaly Aspirated.
It's naturally aspirated. And you avoided my question?
Old Apr 15, 2003 | 05:52 AM
SR20DEN's Avatar
VQ Wizard
Si
Old Apr 15, 2003 | 05:55 AM
Donkey®'s Avatar
wat
Si
Buono. Quando lei finisce per aggiornare il documento, fatemi sapere. ..DONKEY!
dank4us
34
Jun 10, 2024 03:45 AM
fastcarny
Aug 12, 2015 03:50 PM
13Maximasv
Aug 7, 2015 10:56 AM
yat70458
Aug 3, 2015 01:16 PM
