Question for people with the 6spd. transmission
Old Apr 16, 2003 | 02:05 PM
elmaximo's Avatar
When I drive my 97 auto it shifts roughly at 3000 R.P.M and I maintain 70-75mph at just under 2500 R.P.M. I was comparing it with my 2k2 manual that I just purchased, and with the 2k2 after going thru the gear shifts my R.P.M are at almost 3500 to mantain the same speed. Is this normal? or in your opinion do I have the M.A.F
problem with my car and therefore lossing some power?
Any ideas?
Old Apr 16, 2003 | 02:09 PM
jeepik's Avatar
on my 2k2 MAX with the 6 speed i am at 2600 rpms at 80mph in 6th gear...got that number last night...you sure you in 6th gear???
cuz its throttle by wire and you cant really tell, i know it is far fetched but could you be in 4th????
Old Apr 16, 2003 | 02:13 PM
elmaximo's Avatar
That is what I thought at first, that some how I shifted to the wrong gear and did not hear the engine rev. up cause I had the stereo
cranked up, but no, I checked and I was in 6th. gear.
Old Apr 16, 2003 | 04:13 PM
rujorujo's Avatar
I agree with jeepik. I get the same rpms as he does in my 2k2 6spd.
Old Apr 16, 2003 | 04:30 PM
nismotech's Avatar
6th gear @ 60MPH = 2000RPM
6th gear @ 80MPH = 2500RPM
6th gear @ 90MPH = 3000RPM
Old Apr 16, 2003 | 05:09 PM
vito1281's Avatar
I have the exact same thing.
Old Apr 16, 2003 | 05:18 PM
elmaximo's Avatar
Thank you for your feedback guys. I'm going to pay close attention next time I drive on the freeway. Is the loss of power a symptom of a bad M.A.F?
Old Apr 16, 2003 | 05:20 PM
swallac2
Man first headlights, now there stealin' gears!!
Old Apr 16, 2003 | 05:21 PM
elmaximo's Avatar
Old Apr 16, 2003 | 05:22 PM
vito1281's Avatar
I think a MAF failure would not allow you to get over 2500 rpms, or something like that. Are you able to redline the car right now in any gear? If you are, then your MAF should be fine.
So you're saying that you're cruising at 3500 rpms at 70-75 mph? Is your e-brake completely disconnected? Are you ABSOLUTELY positive your shifter is in the right gate (ie. 6th)?
If everything checks out, take it to the dealership. You should still be under warranty.
Old Apr 16, 2003 | 05:33 PM
elmaximo's Avatar
I checked everything you mentioned. I was in 6th. no e-brake.It just happened last night and hve not driven the car today, so hopefully it is a fluke, but if not I will have to have the dealer chek it out for me.Car has only 400 miles, so warranty is not an issue
Old Apr 16, 2003 | 06:11 PM
kratz74's Avatar
You couldn't have been in 6th unless your clutch was spinning. It has to do with engine speed and transmission speed....
Old Apr 17, 2003 | 02:36 PM
swallac2
Exactly, so if you step on the gas and then back off does the car jerk, or does it seem to slip?
Old Apr 17, 2003 | 03:12 PM
Galo's Avatar
Maxima Pilot
Huh???? The gear ratios on your old
automatic are completely different from the gear ratios on the new manual; the first four gears on the manual box are MUCH SHORTER (higher numerically) than the first three gears in your old slushbox, this is why the RPMs need to be much higher to maintain same vehicle speed in your new car.
This is really basic stuff here...
Old Apr 18, 2003 | 04:21 AM
wdave's Avatar
The speedo reads transmission rotations, the tach reads engine rotations. In a stick shift there is no elastic connection between the engine and transmission (no torque converter) - they are mechanically connected by the clutch. The relation between the two is fixed in each gear. The only way you can get higher rpm at any MPH is either you're in the wrong gear, the clutch is slipping (it would smell by now), the tach is way off or the speedo is way off.
Old May 16, 2003 | 02:48 PM
code_slinger's Avatar
I got a 2003 six speed also. Getting the same rpms as the other posters.
When you shift into 6th, you have to first firmly push the stick to all the way to the right, then pull back.
there is absolutely no way for you to get the high rpm you reported unless you were in 4th.
sctludwig
Sep 1, 2022 01:32 PM
I<3 A32's
Sep 10, 2015 11:07 AM
boomerbrian
Sep 4, 2015 08:25 AM
Samedi
Sep 3, 2015 01:07 PM
Johnny9595
Sep 3, 2015 05:18 AM
