Wicked shocks when getting out?
Old Jan 19, 2001 | 10:52 AM
JAV
Anyone out there experiece any extreme shocks when getting out of their Maxima's? I recently purchased a 2001 SE and almost everytime I get out you can almost see the electric shock coming as you reach to shut the door closed. Sometimes minor but other times it's a @#$$%%$##@ powerful shock. Just curious to see if anyone is having the same issues. Any fixes?
Old Jan 19, 2001 | 11:02 AM
2Maxed-out4u's Avatar
Yeah, it only happened to me once, which was the other day. I reached to close door, and felt a shock. About your case, that's weird, cause I know a lot of electronical equipment in the car use your car body as a ground. Better get that checked out real quick.
Old Jan 19, 2001 | 11:08 AM
max2001se's Avatar
Don't know about fixes but I got a new 01 Se and the same damn thing happens to me. And yeah, sometimes it's a pretty nasty shock. I guess from now on I'll let my wife touch the car first
Old Jan 19, 2001 | 11:11 AM
acMAX's Avatar
hmmmm........
haven't felt a single shock yet........either I'm lucky or the nerves in my fingers are damaged.
Old Jan 19, 2001 | 11:16 AM
Weasel's Avatar
My car shocks my friends to death every time the temp drops below 50 degrees or so... it never seems to shock me though. Good loyal car . It depends a lot on the tires, and how well they hold a charge. In extreme cases your car can build up a charge that will zap toll collectors after highway driving.
Old Jan 19, 2001 | 11:24 AM
dougb's Avatar
I too get zapped everytime....
but I am thinking it is from having the heater on. I really do not remember this happening when it was warmer. So hang in there....spring is only 8 weeks away !
Old Jan 19, 2001 | 11:58 AM
Adboy's Avatar
Me too!
I thought it was just me... mine shocks the living $%^& out of me every time I get out of it if the temp. is below 40 or so.
For a while there, I was even popping my door with my shoulder to just go ahead and get it over with... it hurts less there than on a finger tip if you ask me.
Nasty shocks. Any fix for this at all?????
Old Jan 19, 2001 | 12:02 PM
mdeal's Avatar
This happens to me all of the time when the temperature is cooler. It did not happen today. It is raining today.
Old Jan 19, 2001 | 12:24 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
I get shocked when it's really cold outside. Use your key and touch metal before you close your door... it'll help.
Old Jan 19, 2001 | 01:35 PM
punkdork's Avatar
I posted a thread on this a long while back. I get shocked a lot but unlike most of you it seems to have died down in the colder weather... or perhaps with the cars age?
Old Jan 19, 2001 | 02:49 PM
2000MaxSE's Avatar
Re - Shocks Cloth Seats
Do all you Maxima owners that are getting shocks have cloth seats? I have leather seats and I never get shocked. The car before had cloth seats and boy did I get some nasty shocks. Just like in the house when you walk across the carpet you can get a static build up until you touch something that is grounded.
Old Jan 19, 2001 | 03:31 PM
Y2KevSE's Avatar
I *ZAP* have *ZAP* leather... *ZAP*
Old Jan 19, 2001 | 04:01 PM
Proceedbob's Avatar
Go to Auto Palace, est. and get yourself a grounding strap and attach it under the car to a clean metal anchor point. It's basically a carbon impregnated rubber strap that drags on the ground and bleeds off excess electron differential. They are quite effective at eliminating the zaps; cool dry weather intensifies the symptoms. There is nothing electrically or mechanically wrong with your ride. Older American iron with the vinyl seats could stop your heart!
Old Jan 19, 2001 | 04:31 PM
punkdork's Avatar
Re: Re - Shocks Cloth Seats
I've got spring fresh cloth.
Old Jan 19, 2001 | 04:40 PM
ScottMax's Avatar
Try getting completly out of the car with both feet on the ground before touching the outside of the door to close it. Nearly every car I have had has shocked me. My Grand Cherokee has shocked me from 4 inches away!! Ouch!
Old Jan 19, 2001 | 04:49 PM
blew226
Leather no shocks. I've had cloth on the last 4 cars and used to get shocked all the time.
Old Jan 19, 2001 | 07:07 PM
bullseye's Avatar
I get shocked every once in a while, too. Most of the high performance aftermarket tires have silicone in the tread compound. You get better traction in the wet with them, but they will build up quite a charge. If you MUST stop on the side of the road to take a leak... you might want to stand well away from your car. Zzzzzzzzzzzzzzzzzzzzzzzzap!
Old Jan 19, 2001 | 07:22 PM
LeoB's Avatar
try different shoes
the only time I ever get shocked is when i wear runningshoes.. any other kind of shoe..say like Docs..no shocks!
Old Jan 19, 2001 | 09:33 PM
Maxima-Ness's Avatar
Ive gotten to the pointe where i slap the door to check if its going to shock me it must look weird sometimes to other people cause i hesitate every time i get out of my car, and bide my time before closing the door, and then, as always ZAP!!! and it doesnt tickle either!
Old Jan 19, 2001 | 10:07 PM
mingo's Avatar
hahaha mister sparkle...
i think what u can do is attache a chain to the car and let it drag on the ground, real loud and ugly but should work. or a metal cable or something.
Old Jan 20, 2001 | 12:05 AM
NuJerseyDrive's Avatar
Man I hate them shocks. It happens so often that you kinda prepare urself for it each time you step out of your ride. I seriously thought I was the only one...
Old Jan 20, 2001 | 10:39 AM
UMD_MaxSE's Avatar
Got Bent?
I get shocked also and some of them are pretty vicious. Try this next time: Hold the inside metal part of the door frame while geting out and before you put your feet on the ground. This will allow the charge to pass through your body to ground. It works for me whenever I remember to do it.
Old Jan 20, 2001 | 11:14 AM
xtantmaxima's Avatar
I second that.
Old Jan 20, 2001 | 08:36 PM
speedracer's Avatar
DAMN!
YEAH! DO I EVER GOT SHOCKED!!!!! my auto gle.. black leather gets me all da time!!!! i didnt notice it with the warmer wheather.. but when it got colder it has really been getting to me!!! i to always slap the door to make sure there is not shock, but there is a shock!!!!! and when i get out to open the door with my key.. u can see the electrical shock from the key to the doorlock.. OOOOOH.. and once.. i got out of the car.. and there was no shock when i closed the door..(i was wearing leather gloves that day) but when i went to ring my friends door bell..... *ZZZZZZZZAAAAAAAAAAPPPP* YYYEEEAAAAAOOOOHHHHH!!!!!!!!!!
FRIG! the most amazing thing i every saw happened! it was like i possessed some power.. and a blue sort of like fireball of electricity went all around the doorbell!!! its like i shot a electrical fireball all around it! it looked amazing cause it was BLUE!!! haha but it hurt like hell!!!
i thought i was going to fall back cause it was so strong! hahaha damn.. what is wrong with de car? again i have leather seats.... but i also have seatblet dtraps.. the ones that lessen the braking shock... they are cloth material.. that may be a contributor.... i want it to STOP!
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Stagnet04
Sep 14, 2015 11:28 PM
